[Qgis-user] Exporting QGIS map to KML/KMZ
Charles Dixon-Paver
charles at kartoza.com
Fri Aug 13 08:20:13 PDT 2021
I think it would be a lot easier to use the KML Tools algorithms to iterate
over all the layers, then simply drag all the output KMZ files into Google
Earth and export the folder containing them to a consolidated KMZ file. You
can use PyQGIS, e.g:
layers = [layer for layer in QgsProject.instance().mapLayers().values()]
out_dir = 'P:/data/kml_output'
for layer in layers:
if layer.type() == QgsMapLayer.VectorLayer:
try:
layer_src = str(layer.source()).replace('\\','/')
layer_file = os.path.join(out_dir, str(layer.name()) + '.kmz')
processing.run("kmltools:exportkmz", {
'InputLayer': layer_src,
'NameField': '',
'DescriptionField': [],
'ExportStyle': True,
'UseGoogleIcon': None,
'AltitudeInterpretation': 1,
'AltitudeMode': 0,
'AltitudeModeField': '',
'AltitudeField': '',
'AltitudeAddend': 0,
'DateTimeStampField': '',
'DateTimeBeginField': '',
'DateTimeEndField': '',
'PhotoField': '',
'OutputKmz': layer_file,
'LineWidthFactor': 2,
'DateStampField': '',
'TimeStampField': '',
'DateBeginField': '',
'TimeBeginField': '',
'DateEndField': '',
'TimeEndField': ''
print('Exported: ' + layer_file)
except Exception as err:
print(err)
Of course you could try unpack the data and stitch it in python too, but
that's not as easy... But at least the styling etc will be managed for you.
Regards
On Fri, 13 Aug 2021 at 16:50, Richard McDonnell <richard.mcdonnell at opw.ie>
wrote:
> Hi,
> You can do this, but it requires a few steps. Open up the Project where
> the Layers are and they are all styled as you want
> *STEP1 Convert all to KMZ*
> 1. In the *Processing Tools *under* GDAL, Vector Conversion *highlight
> *Convert format *right click and select* Execute as Batch Process*
> 2. Click the* + *symbol to add additional rows and select the
> Layers you want to convert
> 3. Click on the three dots on the right for the first layer, set
> the Save as type to KML set a location and in the file name we are just
> going to give it a prefix, type something like 01_ then click save
> 4. You will then be presented with the *AutoFill* option, set the *Autofill
> mode* to *Fill with parameter values* and set the *Parameter to use* to *Input
> Layer*, at this stage you can delete the prefix manually if you wish
> 5. Click Run
> This should have saved out all Shapefiles as KML’s for you. Now for the
> Styling and fixing of styles
> *STEP2 Apply Styles to KML*
> 1. Right click on one of the original Layers in your project,
> select *Styles, Copy Style, All Style Categories*
> 2. Right click on the corresponding KML select *Styles, Paste
> Repeat for all other Layers
> *STEP3 Final Step*
> 1. In the Search baron the Processing Toolbox search for *Package
> Layers*
> 2. Select the *KML* Files as your *Input Layers*
> 3. Make sure the* Save layer Styles into GeoPackage *
> 4. Click on the three dots at *Destination GeoPackage*, selecting *Save
> to File*, set the Location and Name of the GeoPackage, click *Save* and
> then click *Run*
> The result will be a GeoPackage file with the KML’s saved and the Styles
> applied, which means that anyone who opens the GeoPackage in another QGIS
> Project will always have the Styles applied.
> I don’t believe there is an automated process that will do this for you,
> but you could also look at the model builder and using the steps above as a
> guide, build a custom process which will do the three steps I have outlined
> above in a single step for you.
> Hope that helps,
> Richard McDonnell
> Richard McDonnell MSc GIS, FME Certified Professional
> *FRM Data Management*
> Oifig na nOibreacha Poiblí
> Office of Public Works
> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
> Jonathan Swift Street, Trim, Co Meath, C15 NX36
> M +353 87 688 5964 T +353 46 942 2409
> https://gov.ie/opw
> To send me files larger than 30MB, please use the link below
> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
> Email Disclaimer:
> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *krishna
> Ayyala
> *Sent:* 13 August 2021 14:06
> *To:* qgis-user <qgis-user at lists.osgeo.org>
> *Subject:* [Qgis-user] Exporting QGIS map to KML/KMZ
> Hello,
> I am reposting this question. I have a QGIS map saved
> with ".qgz" extension. This map has four layers. One layer has points, one
> layer has lines and two layers have polygons. Is it possible to convert the
> entire map to kmz without losing the symbology. I know how to convert each
> layer into kmz. But, I am exploring to see if I can convert the entire map
> to kmz?
> Regards.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210813/7bedda59/attachment-0001.html>
