[Qgis-user] How can I export Vector & Raster layers together to import into mapshaper
Kris Lagocki
kris.lagocki at gmail.com
Fri Aug 13 09:50:48 PDT 2021
Hi Everyone: Thanks so much for your suggestions. I'm using Mapbox per
Richard McDonnell's advice and so far I think I am getting what I need.
Consider this case closed. THANKS ALL!
On Thu, Aug 12, 2021 at 12:48 PM Kris Lagocki <kris.lagocki at gmail.com>
wrote:
> I think everything that I want to do can be accomplished using the ArcGIS
> visual within Power BI but then the shape file I created needs to be put
> onto their server as a public map and also I would need to buy a license
> for their product. UGH.
> On Thu, Aug 12, 2021 at 12:44 PM Ben Hur Pintor <bnhr.xyz at gmail.com>
> wrote:
>> Hi Kris,
>> I see. As I mentioned, you can't save the XYZ tile layer as a local file
>> (either as a raster or vector) as it is served as tiles (e.g. images)
>> served from online.
>> One solution is to load the XYZ tile layer as a basemap layer in PowerBI.
>> If this is not available in PowerBI and you need it to be TopoJSON, I'm not
>> sure it's possible to convert a raster to a TopoJSON while still
>> maintaining the features shown by the raster image. TopoJSON being
>> primarily a vector file format and not meant to serve tiles/images. The way
>> that I know that you can serve vectors as tiles is via Vector Tiles like
>> MVT (Mapbox Vector Tiles).
>> If you can load raster data in PowerBI (e.g. georeferenced PNG or TIFF
>> file), another solution would be for you to create a printable map of the
>> part you want to save as a raster (e.g. PNG or PDF) and ensure that this
>> output map is georeferenced. You should then be able to load the raster in
>> PowerBI if that's a capability PowerBI has.
>> Unfortunately, if PowerBI can only load TopoJSONs, I don't think you'll
>> be able to load the OSM tile layer there.
>> As mentioned by Richard, you can use other basemap providers (in this
>> case Mapbox) if PowerBI supports them.
>> I hope this helps,
>> All the best,
>> Ben Hur
>> *Ben Hur S. Pintor | BNHR <https://bnhr.xyz>*
>> bnhr.xyz
>> hi at bnhr.xyz
>> *BNHR*
>> openness. data. geospatial.
>> On Fri, Aug 13, 2021 at 12:42 AM Richard McDonnell <
>> richard.mcdonnell at opw.ie> wrote:
>>> Have a look at this video, it seems to allow you to utilise MapBox as a
>>> background Map
>>> *https://www.youtube.com/watch?v=N33d7fCVsZw
>>> <https://www.youtube.com/watch?v=N33d7fCVsZw>*
>>> *Regards,*
>>> * Richard.*
>>> Richard McDonnell MSc GIS, FME Certified Professional
>>> *FRM Data Management*
>>> Oifig na nOibreacha Poiblí
>>> Office of Public Works
>>> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
>>> Jonathan Swift Street, Trim, Co Meath, C15 NX36
>>> M +353 87 688 5964 T +353 46 942 2409
>>> https://gov.ie/opw
>>> To send me files larger than 30MB, please use the link below
>>> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
>>> Email Disclaimer:
>>> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
>>> *From:* Kris Lagocki <kris.lagocki at gmail.com>
>>> *Sent:* 12 August 2021 14:40
>>> *To:* Richard McDonnell <richard.mcdonnell at opw.ie>
>>> *Cc:* qgis-user at lists.osgeo.org
>>> *Subject:* Re: [Qgis-user] How can I export Vector & Raster layers
>>> My issue seems to be with the raster layer, can't seem to figure out how
>>> to have it export together with the vector layer.
>>> On Thu, Aug 12, 2021 at 5:27 AM Richard McDonnell <
>>> Hi,
>>> There is a TopoJSON Writer Plugin available for QGIS, you might give
>>> that a try. It should write the vector dataset out as TopoKSON for you.
>>> Regards,
>>> Richard
>>> *Richard McDonnell MSc GIS, FME Certified Professional*
>>> *Oifig na nOibreacha Poiblí*
>>> *Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36 *
>>> https://gov.ie/opw
>>> Email Disclaimer:
>>> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Kris
>>> Lagocki
>>> *Sent:* 11 August 2021 14:32
>>> *To:* qgis-user at lists.osgeo.org
>>> *Subject:* [Qgis-user] How can I export Vector & Raster layers together
>>> Hi - I created a shape file using QGIS with a US Postal Code shape file
>>> that I found on the Census website and joined it with a data file listing
>>> the Postal Codes and which Sales Territory they belong to. I added in a
>>> raster layer OpenStreetMap. I'd like to export both layers together and
>>> import them into mapshaper so that I can export as Topojson. It has to be
>>> in this format to use within Power BI. Has anyone accomplished this? Any
>>> help is appreciated. Thanks.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210813/e2354072/attachment.html>
