[Qgis-user] Layer Ordering for KMZ
krishna Ayyala
ayyalakrishna at gmail.com
Sat Aug 14 17:19:06 PDT 2021
Andrea,
Thanks for your reply. I am also using the exact same version7.3.4.8248
(64-bit). But it is not always that I am getting "small points" above the
"big points". Just now, I checked, I see only 3 small points above the big
points while one is behind the big point. Second time when I open I see
only two small points above the big points.
Regards
On Sat, Aug 14, 2021 at 4:28 PM Andrea Giudiceandrea <andreaerdna at libero.it>
wrote:
> krishna Ayyala Sat, 14 Aug 2021 09:24:06 -0700
> > I am attaching the sample data which contains the
> > shapefiles and the kmz file. There are four small points (A,B,C,D) that
> > should fall on top of four big points (E,F,G,H).
> > Each time I open the kmz, I am getting different results. One time I
> > donot see any of the small points.
> Hi krishna Ayyala,
> every time I open the Points_KMZ.kmz file with Google Earth Pro
> 7.3.4.8248 (64-bit) on Windows 7, I always see the "small points" above
> the "big points".
> Best regards.
> Andrea
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210814/bbcef514/attachment.html>
