[Qgis-user] Atlas - Make sourrounding of Coverage Layer transparent
Andreas Neumann
andreas at qgis.org
Thu Aug 19 06:18:26 PDT 2021
Hi Roland,
You can achieve this with the "inverted polygon" renderer where you
basically style all areas outside of the current atlas polygon - typically
used with some transparency to make the non-atlas feature "lighter".
Or with the rule-based renderer where you can ask if the atlas-id is the
same as the current feature id, a rule similar to:
pk_column = attribute(@atlas_feature,'pk_column')
and then style the atlas feature differently (or not at all) as all other
features (ELSE rule).
If you want this for atlas print only, you could create a separate,
additional style for this, or an extra set of layers that are only
displayed/printed in the atlas layout context.
Let us know if you need some more assistance for either option.
Greetings,
Andreas
On Thu, 19 Aug 2021 at 15:02, Roland Spielhofer <rspiel at gmx.net> wrote:
> Hi,
> I use a polygon layer as coverage layer for creating an atlas.
> What I would like to have is that everything outside of the polygon shown
> on the atlas page is shown transparent.
> The inside of the polygon should display normal.
> I made a picture showing what I would like to achieve. The left side of
> the dotted orange polygon (=coverage layer) is what I am looking for.
> https://imgur.com/a/1UXgFKr
> How can this be done?
> Regards,
> Roland
> Qgis-user mailing list
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210819/ccc6ab4e/attachment.html>
