[Qgis-user] Python for qgis
    Tudorache, Marian
    Marian.Tudorache at navcanada.ca
    Mon Aug 23 05:35:56 PDT 2021
This is a nice tutorial and they have a section about Python Programming in QGIS
https://www.qgistutorials.com/en/
https://www.qgistutorials.com/en/docs/getting_started_with_pyqgis.html
Books:
https://docs.qgis.org/3.16/en/docs/pyqgis_developer_cookbook/index.html
https://courses.spatialthoughts.com/pyqgis-in-a-day.html
If you search using “pyqgis” as keyword you will find out more material.
Good luck!
Marian
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Alexandru Munteanu
Sent: August 21, 2021 11:18 AM
To: qgis-user at lists.osgeo.org
Subject: [EXT] [Qgis-user] Python for qgis
CAUTION: This email originated from outside of the organization. If you do not recognize the sender or you are not certain the content is safe, then do not click on any links or open any attachments.
AVERTISSEMENT : Ce courriel provient d’une source externe à l’organisation. Si vous ne reconnaissez pas l’expéditeur ou si vous doutez de la sécurité du contenu, ne cliquez sur aucun lien et n’ouvrez aucune pièce jointe.
Hi community!
I am wondering if you can help me with information / resources where i learn using Python for qgis. I have taken a basic course on Python, but i am sure I need to extend my knowledge on how to apply it in qgis.
Thank you in advance for any help you can provide and sources where I can find more information on that.
Best,
Alex
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210823/b2015c0c/attachment.html>
