[Qgis-user] Outer border only + fill
Dario
dario955i at gmail.com
Mon Aug 23 23:14:15 PDT 2021
Thank you very much. Unfortunately we must use only long term release... I’ll wait for the update
_
Il giorno 24 ago 2021, alle ore 00:12, Alexandre Neto <senhor.neto at gmail.com> ha scritto:
Dario, QGIS 3.20 has now a merged renderer that you may want to check.
A segunda, 23/08/2021, 15:40, Charles Dixon-Paver <charles at kartoza.com> escreveu:
> You could use a geometry generator symbol style. Not sure of the best expression for it but even something like if("fid"=1,buffer(collect($geometry),0),0) should work
> On Mon, 23 Aug 2021, 16:25 Dario C, <dario955i at gmail.com> wrote:
>> Hi,
>> I have road layer with several pieces of geometry.
>> is there any way to display like a unique polygon? I mean like a merged geometry?
>> I'm able to do it only making a duplicate and assigning "Inverted polygons" with "merge polygons before render" option.
>> Thank you.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210824/d58e4822/attachment.html>
