[Qgis-user] Rule-based symbol for point within polygon in QGIS
    Stefan Giese (WhereGroup)
    stefan.giese at wheregroup.com
    Mon Aug 30 08:10:56 PDT 2021
Depends on your QGIS version, from 3.16 onwards you can use the
overlay-functions to proof if the point and polygonlayer are in a
spatial relation like intersects or touches and so on. The expression
for your first rule will be like this one:
/"VAL_PROTECTION_EP3" = '1' AND  "TYPE"  = 1 AND overlay_intersects(
layer:='pol', filter := ("TYPE" in ('P','E') AND "CAT_CANTON" = 2) OR
("TYPE" in ('P','E') AND "CAT_CANTON" = 3))/
In the overlay_intersects-part you have to change the layername to your
polygon layer.
If you have an older QGIS Version you can achieve the more or less same
result with the refFunctions Plugin.
Hope this helps
Best regards
Stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Jetzt neu: Webinare und Online-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 30.08.2021 um 16:36 schrieb Jeanneret Cédric:
> I would like to use a set of rules to draw features from a point_layer
> that are within a polygon_layer.
> Points that answer true to
> ("VAL_PROTECTION_EP3" = '1' AND  "TYPE"  = 1)
> and that are within polygons that answer true to
> ("TYPE" in ('P','E') AND "CAT_CANTON" = 2) OR ("TYPE" in ('P','E') AND
> "CAT_CANTON" = 3)
> should be displayed as red dots
> ("VAL_PROTECTION_EP3" = '2' AND  "TYPE"  = 1)
> "CAT_CANTON" = 3)
> should be displayed as orange dots
> ("VAL_PROTECTION_EP3" = '3' AND  "TYPE"  = 1)
> ("TYPE" in ('P','E') AND "CAT_CANTON" = 1)
> should be displayed as yellow dots
> I cannot find the right combination of expressions for the rule to work.
> Any help would be appreciated: what would a working syntax be for such
> a rule to work in QGIS Layer Styling panel ?
> Cédric Jeanneret
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210830/3aa83ba7/attachment-0001.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210830/3aa83ba7/attachment-0001.sig>
