[Qgis-user] MapInfo export issue
Nicolas Cadieux njacadieux.gitlab at gmail.com
Wed Dec 1 06:41:10 PST 2021
I checked my old files and looks like the Mapinfo never used the .prj extension for the projection info.  I was confusing the old .qpj file format that was used for the shapefiles a while ago. That format was a temporary fix.  Looks like Mapinfo store the info in the .map file.  This can be seen more clearly if you export the file to the MID/MIF format as pointed out by others.
You say QGIS no longer exports the projection in the output when saving to Mapinfo format.  Can’t you check the mid-mif export file or use OGRINFO to see if this is correct?
https://gdal.org/programs/ogrinfo.html
Another possibility is that you are using, in QGIS, a projection that is not recognized by Mapinfo.  This could be the case if a files opens in the correct crs in QGIS but not in Mapinfo.   You may need to update the Mapinfow.prj file with the unrecognized projections….  That file stores all the Mapinfo world projection and it can be manually edited with a simple text editor like notepad++
https://customer.precisely.com/s/article/Adding-custom-projections-for-use-in-MapInfo-Pro?language=en_US
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 30 nov. 2021 à 16:15, Nicolas Cadieux <njacadieux.gitlab at gmail.com> a écrit :
> Hi,
> I tested exporting a .shp using 3.20.3.  I see no prj file but the file CRS is correctly positioned.  It's possible the .prj extension was a temporary fix???  Test in MapInfo.
> Nicolas
> On 2021-11-30 1:04 p.m., Paul Wittle wrote:
>> Hi,
>> I was just about to try and push out version 3.16.14 but it has been pointed out that if you export to MapInfo tab file it is no longer saving the projection in the output.
>> Is anyone else finding that the resulting files are doing this and is there a work around using say gdal options?
>> Sorry if I missed another message about this as I see the Windows build has been proving problematic and we are Windows users,
>> Paul
>> This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/data-protection
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211201/c1c39c63/attachment.html>
