[Qgis-user] is there a way to clip a shapefile without changing it from point to multipoints?
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Tue Dec 7 17:58:32 PST 2021
You may have a multipoint file as input consisting of single points. You can look at the file properties to see and you can use a function in the field calculator to count the number of parts in an object. You can also use the multipart to single part function under the vector menu.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 7 déc. 2021 à 10:06, Katrin Schneider <Katrin.Schneider at ufu.de> a écrit :
> Hi,
> (QGIS 3.20.3)
> Work-Process:
> 1. I had to clip my layer A(points) with shapefile B (polygon). The resulting layer C is multipoint despite consisting only of points.
> 2. I tried several methods to edit the layer C
> a) Export it as point-shapefile -> error
> b) Multipoint to point -> umlauts/mutated vowels are not readable anymore
> Kind regards,
> Katrin
> Katrin Schneider
> FG Naturschutz & Umweltkommunikation / Fachgebietsleiterin
> Unabhängiges Institut für Umweltfragen - UfU -
> Büro Halle
> korina | Koordinationsstelle Invasive Neophyten in
> Schutzgebieten Sachsen-Anhalts beim UfU e.V.
> Große Klausstr. 11, 06108 Halle/Saale
> Telefon 0345 202 65 30, Fax 0345 685 85 216
> www.korina.info, www.neophyten-in-der-landwirtschaft.de
> KORINA-Newsletter
> <image002.png>
> <image004.jpg>
> <image006.jpg>
> Das UfU braucht Unterstützung!
> Jetzt Spenden oder Mitglied werden
> und ein Teil der UfU Familie sein!
> Hier finden Sie unsere neusten Publikationen.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211207/5c9bafa5/attachment.html>
