[Qgis-user] Newby question on mapping information
    Miro Lucassen
    miluc at mirolucassen.nl
    Thu Dec  9 14:49:33 PST 2021
Thanks Stefan & Bernd, this should bring me further. I am wrestling now with different attributes of the relevant fields, time for a good night sleep. I should be able to overcome this last issue tomorrow.
Miro
> Op 9 dec. 2021, om 20:04 heeft Stefan Giese (WhereGroup) <stefan.giese at wheregroup.com> het volgende geschreven:
> Miro,
> may be you have a look to that and other tutorials from Ujaval, where some steps mentioned by Bernd are explained: http://www.qgistutorials.com/en/docs/3/performing_table_joins.html
> Best regards
> Stefan
> Am 09.12.2021 um 18:51 schrieb Bernd Vogelgesang:
>> Hi,
>> from what I read and understand:
>> 1. "with separate layers for boundaries of each plot and unique" If I
>> understand this correctly, every polygon has a unique layer?
>> Then Processing -> Toolbox -> Merge vector layers
>> If I understood this wrong, skip this step.
>> 2. Toolbox -> Join attributes by field value -> Pick your boundaries
>> layer and the csv and set the common field
>> 3. Layer properties -> Symbology -> Change from Single Symbol to
>> Categorized -> pick a field from which you can distinct the ownership ->
>> Classify
>> Good luck
>> Am 09.12.21 um 17:57 schrieb Miro Lucassen:
>>> Hi, this is probably easy for experienced users, but I am stuck in the interface as this is my first project in QGIS.
>>> Aim of project: map of a part of an Dutch municipal authority, marked areas that are owned by the local authorities.
>>> Input 1: KML-file of all registered property (kadaster) in the relevant area plus a bit more, with separate layers for boundaries of each plot and unique ID, including geo-information
>>> Input 2: CSV-file of all property owned by the Municipality in the relevant area plus a bit more, with same ID as the general KML-file, no geo-information
>>> I see the map of all property, I have imported the municipality-plots as a separate layer, but now what? How do I connect the relevant property to the map, and how do I create a visualisation that shows the plots owned by the Municipality?
>>> Any help is greatly appreciated.
>>> Miro Lucassen,
>>> The Netherlands
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Aufwind durch Wissen!
> Jetzt neu: Webinare und Online-Schulungen
> bei der www.foss-academy.com
> WhereGroup GmbH
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Fon: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
