[Qgis-user] Buffer by Attribute Issue
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Wed Dec 15 08:01:31 PST 2021
sorry, but can't reproduce your problem (but on Linux Mint QGIS 3.22).
Generated 100 random points and added a field "buffer" from $id*10.
Everything fine here.
Bernd
Am 15.12.21 um 16:26 schrieb Peter Devanney:
> Hi Folks
> Have a table full of points that I want to buffer by a variable
> distance. The distance is an attribute in the input table in km.
> Using Vector>Geoprocessing>Buffer It works fine if I specify a fixed
> buffer.
> When I run it with the attribute selected it runs fine but it will not
> paint the buffers. At first I thought I had a unit issue so added an
> expression to multiply the attribute by 1000 to get to km from m as I
> wasn't sure if the default was m.
> The buffered output behaves totally normally so I can label, and zoom
> to features... All looks fine except no actual buffers draw. Symbology
> panel looks normal.
> Just wondering if anyone has seen this or knows of a workaround or
> thoughts on what I am doing wrong.
> I am running 3.16.8 Hannover on mac OS 11.6
> thanks
> Peter
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211215/c88bdb05/attachment-0001.html>
