[Qgis-user] Buffer by Attribute Issue
Peter Devanney peter at devanney.ca
Thu Dec 16 12:36:56 PST 2021
Chris and list
It is working for me now.
Sorry, when I said lat/long I had meant the points were imported as
Lat/Long EPSG:4326 from a text file. But subsequently projected to 3857.
Example point in the project CRS ( EPSG:3857) -11923424,5461258
So I think I found the problem. Seems one workflow works and the other
doesn't. You must select the Attribute Field from the field list and then
edit the expression. This works. I thought I had tried it yesterday but
suspect I didn't have the expression right. What I spent time with was
using the Assistant dialog. That did not work. I was able to reproduce that
it does not work.
So the workflow that works is select the attribute Field and then go to
Edit the Expression. I was unable to get it working using the Assistant
dialog.
thanks for the great help!
Peter
On Thu, Dec 16, 2021 at 2:50 PM chris hermansen <clhermansen at gmail.com>
wrote:
> Peter and list
> On Thu, Dec 16, 2021 at 7:08 AM Peter Devanney <peter at devanney.ca> wrote:
>> Chris
>> The buffer input is a point the lat and long are Doubles. The buffer
>> distance variable is a Double. Using EPSG 3857 for all.
> I just created a point shapefile in EPSG:3857, added a field called
> "bufferdist", added three points with bufferdist set to 1000, 2000 and 5000
> respectively.
> EPSG:3857 is in metres, are readily visible and as far as I can tell from
> measuring the buffers were correctly created in the correct size.
> In the buffer dialogue did you click on the button next to the distance /
> units pair and next to "field type >" select your field, which would
> deactivate the distance / units pair?
> Your mention of "lat and long" troubles me.  EPSG:3857 is a projected
> coordinate system, not a lat/lon system.
>> Not sure what the protocol on the list is or if it will accept a small 2
>> MB .mp4 but I can show what I am doing for workflow if that might help?
>> thanks Chris
>> Peter
>> On Wed, Dec 15, 2021 at 6:42 PM chris hermansen <clhermansen at gmail.com>
>> wrote:
>>> Peter and list,
>>> On Wed, Dec 15, 2021 at 7:26 AM Peter Devanney <peter at devanney.ca>
>>> wrote:
>>>> Hi Folks
>>>> Have a table full of points that I want to buffer by a variable
>>>> distance. The distance is an attribute in the input table in km.
>>>> Using Vector>Geoprocessing>Buffer It works fine if I specify a fixed
>>>> buffer.
>>>> When I run it with the attribute selected it runs fine but it will not
>>>> paint the buffers. At first I thought I had a unit issue so added an
>>>> expression to multiply the attribute by 1000 to get to km from m as I
>>>> wasn't sure if the default was m.
>>>> The buffered output behaves totally normally so I can label, and zoom
>>>> to features... All looks fine except no actual buffers draw. Symbology
>>>> panel looks normal.
>>>> Just wondering if anyone has seen this or knows of a workaround or
>>>> thoughts on what I am doing wrong.
>>>> What is the type of your buffer item?  What are the typical values?
>>> What is your CRS?
>>> Chris Hermansen · clhermansen "at" gmail "dot" com
>>> C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211216/de04a6e6/attachment.html>
