[Qgis-user] Importing Polygon into QGIS
Nicolas Cadieux njacadieux.gitlab at gmail.com
Fri Dec 24 15:05:05 PST 2021
The red polygon is not a vector layer so you can’t import it.  You can however create a polygon in Google earth and then export to kml or kmz.  You can import those in QGIS.  You can also use a plugin like quickmap services, add third party servers in the plugin options and vectorize in QGIS using Google map as a background.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 23 déc. 2021 à 11:58, krishna Ayyala <ayyalakrishna at gmail.com> a écrit :
> I am Reposting this question.
> Regards.
> Hello,
> In the google maps, I have typed Leduc, Alberta. I got the the following weblink with the red polygon as shown in the map. Is it possible to import this polygon into QGIS? If not, Is it possible to get the coordinates of the entire polygon so that I can geocode in QGIS. Pasted the link below.
> Regards.
> https://www.google.com/maps/place/Leduc,+AB/@53.2670139,-113.5807581,12.5z/data=!4m5!3m4!1s0x539ff973e9beae87:0xacd75f8bc5016a60!8m2!3d53.2646889!4d-113.5527442
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211224/730d31d0/attachment.html>
