[Qgis-user] open specific form
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Mon Feb 1 06:18:49 PST 2021
The join function in QGIS is capable of making editable joins :
See the attached project and geopackage.
1 gotcha: Both layers in the relation (geometry and attribute layer) has
to be marked "editable" before you can edit the values from the joined
layer
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 01-02-2021 kl. 13:05 skrev Raphael d'Epagnier:
> Hello everyone,
> I have only been working with QGIS for a short time.
> I have a point, line and area layer and also an attribute table with
> detailed information about the respective geometry objects. Several
> objects of the different geometry types (point, line, area) can belong
> to the same object in the attribute table.
> The goal is that when I select a point, for example, the information
> from the attribute table should be displayed (attribute table form
> opens instead of point table form). A view is not an option, because
> the data in the form must be editable. Does anybody know how to do this?
> An alternative could be a button on the geometry form, to open the
> attribute table. Any idea how to do that with "Drag and Drop" forms? I
> know there would be a possibility with the relation reference. But due
> to a confirmed QGIS problem with more than a hundred entries in the
> tables, I have to use "value relation" instead.
> I have already tried to solve this problem with Qt-Designer, but have
> not been successful.
> Best regards,
> Raphael
> Image
> *GeoplanTeam AG*
> Egliweg 6
> CH-2560 Nidau
> Image
> +41 (0) 32 332 78 00
> Image
> www.geoplanteam.ch<http://www.geoplanteam.ch/>
> Image
> raphael.depagnier at geoplanteam.ch<mailto:raphael.depagnier at geoplanteam.ch>
> Image
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210201/18975efa/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210201/18975efa/attachment-0001.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210201/18975efa/attachment-0005.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210201/18975efa/attachment-0006.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210201/18975efa/attachment-0007.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210201/18975efa/attachment-0008.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210201/18975efa/attachment-0009.jpg>
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210201/18975efa/attachment-0001.bin>
