[Qgis-user] File based Geopackage bugs
    Patrick Dunford
    enzedrailmaps at gmail.com
    Mon Feb  1 18:11:46 PST 2021
I recall going back someway we were sold this Geopackage idea being
implemented into Qgis because it was going to be so much better than
shape files that everyone has been using up to now. I bought into these
ideas by converting shape files in most of my Qgis projects into
Geopackage files.
However there appear to be some serious bugs in Qgis' implementation of
Geopackages as a file based system, and since SQlite has an impeccable
reputation, it is a reasonable conclusion that there must be significant
uncorrected bugs in the Qgis code that deals with file based Geopackages.
Here are two examples:
1. Changing the data table associated with a layer, specifically the
operation of deleting columns, is almost 100% guaranteed to result in
automatic deletion of 100% of the features in the layer when the layer
is saved. I have seen this happen multiple times, whether in a layer
with 92 features or one with half a million.
2. Compared to shapefiles, Geopackages add an extra field called a fid
which is a unique numerical value. For new records, this value is
automatically generated. This requirement of uniqueness and the field
apparently being unchangeable by the end user makes it impossible to
paste features from another table if the values in the fid field for
pasted features happen to coincide with existing entries in the table.
These two examples are making me consider changing back to shapefiles in
all my projects because shapefiles did not cause either of these two
problems. Supposedly a shapefile is more prone to data corruption. This
may be the case but as the code in Qgis that deals with shapefiles
appears to be considerably more mature, these considerations have to be
reasonably weighed against each other.
Particularly in the case of issue 1, this appears to be a regression
since I do not recall it being an issue on Qgis 2.18 or possibly earlier
versions of Qgis 3. (I use the LTS edition of Qgis)
