[Qgis-user] Detail-level of exported maps
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Thu Feb 4 05:21:01 PST 2021
Hi Frederik,
What type of map are you using for your background? I suggest using Vector
Tile map.
Kind regards
Saber
On Thu, 4 Feb 2021 at 13:01, Frederik Franke <frederik.franke at posteo.de>
wrote:
> Dear QGIS users,
> I’m relatively new to QGIS and need a quick help to export a map (as pdf)
> from the QGIS composer.
> My map contains an OpenStreetMap background map and I have the problem
> that the exported OpenStreetMap is much too detailed (e.g. hundreds of
> village names are included with a very small font size). When I change the
> export resolution from 300 dpi to 72 dpi in the composer I can circumvent
> this problem. Only big cities are labeled now and the city names are in an
> appropriate size. Unfortunately the map has a very bad resolution now (I
> can see single pixels when I set the pdf-zoom factor to 100 percent).
> How can I export a map with a lower detail-level but a good resolution?
> Thanks and best
> Fred
> Qgis-user mailing list
Saber Razmjooei
www.lutraconsulting.co.uk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210204/b26e41be/attachment.html>
