[Qgis-user] Issue with "Mesh Calculator" with a GRIB file
Eric Compas ericcompas at gmail.com
Wed Feb 10 04:53:40 PST 2021
Vincent,
Thanks! I updated to 3.16 and the expression worked just fine (once I
figured out the changes to the mesh interface).
Eric
On Tue, Feb 9, 2021 at 9:37 PM Vincent Cloarec <vcloarec at gmail.com> wrote:
> Hi,
> Which QGIS version?
> It seems 3.10.
> Can you try with 3.16?
> Regards.
> Vincent
> Le mar. 9 févr. 2021 à 22:55, Eric Compas <ericcompas at gmail.com> a écrit :
>> All,
>> I'm experimenting with the mesh viewing and analysis tools
>> in QGIS (3.12.3) using both the Crayfish and QGribDownloader plugins. All's
>> going very well, and for the most part, the tools are relatively easy to
>> use.
>> While I've gotten several "Mesh calculator" expressions to work correctly
>> with a GRIB file (downloaded using the QGribDownloader plugin), I'm running
>> into an error with any expression using precipitation group, e.g.:
>> ("Temperature [C]" > 10) and ("03 hr Total precipitation [kg/(m^2)]" < 2)
>> This expression yields an error "Mesh calculator: Invalid or incompatible
>> datasets used." I've tried several permutations and start/end ranges. All
>> without luck.
>> Investigating further, it seems like the number of time "slices" in the
>> precipitation group isn't the same as in the temperature group and may not
>> be handled correctly in QGIS (??). In the temperature group layer
>> properties, the time slider and metadata times are always the same
>> (synchronized).  For the precipitation group, the time slider and metadata
>> in the layer properties aren't in sync:
>> [image: 2021-02-06_10-34-02b.gif]
>> I suspect that the precipitation group has fewer time "slices" that may
>> not be handled correctly and hence the error in the "Mesh Calculator" tool.
>> Is this a user error or some issue with how the mesh tools handle groups
>> with differing number of time "slices?"
>> I'd appreciate any help.
>> Thanks,
>> Eric
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210210/472dcccd/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210210/472dcccd/attachment-0001.gif>
