[Qgis-user] Geometries of labels - automatic positioning (no covering)
Phil Wyatt
phil at wyatt-family.com
Sat Feb 13 15:20:25 PST 2021
Hi Folks,
To turn on the ‘show candidates’ click on the little gear to the right of ‘Single labels” then tick the ‘Show Candidates (for debugging)’
Cheers - Phil
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Matej Mailing
Sent: Sunday, 14 February 2021 8:50 AM
To: Régis Haubourg <regis.haubourg at gmail.com>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Geometries of labels - automatic positioning (no covering)
How can I try this option of the rendering engine that displays the labeling candidate paths so I could play with the number of candidates?
Thanks,
Matej
Dne petek, 12. februar 2021 je Régis Haubourg <regis.haubourg at gmail.com <mailto:regis.haubourg at gmail.com> > napisal(-a):
no magic anwser here again. But when I face this kind of need, I switch
on the option of the rendering engine that displays the labeling
candidate paths, and play a lot with the number of candidates.
Of course, the more candidates, the more CPU work, but the more chances
to have a 99 % good result.
Best luck
Régis
On 12/02/2021 14:02, Matej Mailing wrote:
> Hi Silvio.
> Basically my issue is that I need to have all the symbols and labels
> visible, but since the number of those is huge, I want to have the
> need to place them automatically as much as possible. If somehow I
> could use the collision engine to recalculate the positions - I just
> need the labels to be visible, the exact label position (little more
> to the each side as it must be to avoid colliding) is not important, I
> just need them to be visible near the objects basically...
> Positioning every label by hand takes an enormous amount of time of
> manual work that seems to be meaningless in the current state of
> automation :)
> Thanks,
> Matej
> V V pet., 12. feb. 2021 ob 12:49 je oseba silvio.bentzien
> <silvio.bentzien at protonmail.com <mailto:silvio.bentzien at protonmail.com> > napisala:
>> Hey Matej,
>> please disregard my last message. I got lost in the thread.
>> Would it help your problem if you lock the scale of your project and use the Magnifier to zoom in and out? That way, you can lock the symbols and labels to the scale you want to plot your map in and you would have greater awareness and control over the placement of you labels. (assuming that changing label positions manually is feasible in your case)
>> greetings,
>> silvio
>> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
>> On Thursday, February 11, 2021 3:08 PM, Matej Mailing <mailing at tam.si <mailto:mailing at tam.si> > wrote:
>>> Thanks, I already have this enabled.
>>> What I would like is to achieve this result (img1) instead now having
>>> labels covering each other as in img2.
>>> Thanks,
>>> Matej
>>> V V tor., 9. feb. 2021 ob 14:02 je oseba Matej Mailing
>>> mailing at tam.si <mailto:mailing at tam.si> napisala:
>>>> Thanks,
>>>> Matej
>>>> V V tor., 9. feb. 2021 ob 13:34 je oseba Richard Duivenvoorde
>>>> rdmailings at duif.net <mailto:rdmailings at duif.net> napisala:
>>>>> On 2/9/21 1:29 PM, Matej Mailing wrote:
>>>>>> Hello Regis,
>>>>>> I cannot find that option you mention: "the placement option "always
>>>>>> displays" on the layers"
>>>>>> I seem to have checked all the options - I am using QGIS 3.16.3.
>>>>> See screenshot, it is in the last tab, checkbox "Show all labels for this layer (including colliding labels)"
>>>>> Regards,
>>>>> Richard Duivenvorde
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210214/1d40f9fa/attachment.html>
