[Qgis-user] Please, how to solve this silly issue while trying to install a PY ?
Richard Duivenvoorde rdmailings at duif.net
Sun Feb 14 23:58:50 PST 2021
On 2/15/21 6:24 AM, Allan López wrote:
>     Dear All,
> Best,
> Allan López
>     NameError: name 'progress' is not defined
> Traceback (most recent call last):
>   File "C:/PROGRA~1/QGIS 3.12/apps/qgis/./python/plugins\processing\script\ScriptAlgorithmProvider.py", line 119, in loadAlgorithms
>     alg = ScriptUtils.loadAlgorithm(moduleName, filePath)
>   File "C:/PROGRA~1/QGIS 3.12/apps/qgis/./python/plugins\processing\script\ScriptUtils.py", line 66, in loadAlgorithm
>     spec.loader.exec_module(module)
>   File "", line 728, in exec_module
>   File "", line 219, in _call_with_frames_removed
>   File "C:\Users\allan\AppData\Roaming\QGIS\QGIS3\profiles\default\processing\scripts\Summit surface.py", line 84, in
>     progress.setInfo('Importing DEM...')
In the code Summit surface.py QGIS is trying to call "setInfo('Importing DEM...')" on in instance called 'progress'.
BUT this 'progress' does not excist (yet).
Is it your own code? Or did you change someting in others code?
Do you have this code from github?
Regards,
