[Qgis-user] Symbol lines every km, moving when changing scale or moving map
    Nyall Dawson
    nyall.dawson at gmail.com
    Thu Feb 18 14:29:06 PST 2021
On Wed, 13 Jan 2021 at 06:33, Prud'homme Jérémie <p.jeremie at gmail.com> wrote:
> Hi,
> I'm using QGIS 3.10.
> I tried to use only symbology to display a stroke every km along a road.
> The project CRS is 2154 (Lambert 93).
> When adding a ""symbol line" with an interval of 1000 map units (meter for 2154) – or 1000 meters at scale, same result – I achieve to display symbols every km.
> Problem is when I move the map or change scale, the symbols do not always stay in place. They are sometimes misplaced.
> I've been told that problem can be that the first node of the line is not always the reference to calculate the intervals.
>From the bottom of the symbol widget, click the "Advanced" button and
uncheck "Clip features to canvas extent".
Nyall
> You can find a GIF here that displays my problem : https://zupimages.net/viewer.php?id=21/02/nvr2.gif
> Circles are symbols via Symbology.
> Strokes are symbos on points generated vith the tool "Points along geometry".
> You can see that circles are not always at the same place as the strokes.
> Is it a "normal" behavior ?
> Anyway as a user I would expect that symbols are always generated at the same place from the starting node.
> Thanks for your enlightments on this.
> Jérémie.
> Qgis-user mailing list
