[Qgis-user] snapping polygons together
Thayer Young thayeray at yahoo.com
Tue Feb 23 13:45:50 PST 2021
 Hi Ryan,
This would be clunky but should do what you want:0) turn on editing for your grid layer1) select the feature you want to 'move'2) use the Translate tool    a) check the 'Selected features only' check box    b) enter the desired offset distance for the x and y axis         i) this will be easy to calculate if your grid is regular         ii) otherwise use the measure tool3) if the new feature meets your requirements    a) delete the original, selected, feature from the grid    b) select, copy (control + c) and paste (control + v) the translated feature to the grid layer4) save the grid layer
-Thayer
> Date: Tue, 23 Feb 2021 10:02:33 -0500
> From: Ryan Peel <ryanpeel at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] snapping polygons together
> Message-ID:
>    <CAKaP4zdXNVTAzoO8FXBs7trM-L67MC74d06QuUT7y4ZvryNN5w at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
>I am making a grid layer and I want to copy/move some of them to 'lock'
> into adjacent ones perfectly.  Trying to avoid messing with the vertex
> editor.  zooming in close to the edges never gets it exact.  I don't want
> to drag the corner vertices and snap, I just want to move the whole polygon
> and snap it to the edge of another.  Maybe I'm missing something.
> Sincerely,
> Ryan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210223/21960b34/attachment.html>
