[Qgis-user] raster with distance values from a point
Kirk Schmidt
kirk at nortekresources.com
Thu Feb 25 12:44:18 PST 2021
To add to Nicolas" comment:
1) Create your point layer from a csv (easting, northing id) as a minimum
2) If you want to stay with process modeler, use the SAGA>Raster
creation tools> Rasterize Algorithm to convert the point layer to your
required resolution and size
3) Use the GDAL>Raster Analysis>Proximity or SAGA>Raster tools>
Proximity Raster to create your output.
Kirk Schmidt
On 2/25/2021 4:24 PM, Nicolas Cadieux wrote:
> Hi,
> You can cut down you use of several plugins by doing the following,
> 1) Create a vector point file with a single point having the numerical
> field containing the value 1. This file could be a csv containing WKT.
> 2) Use the vector to raster conversion. (This will take your vector
> point file, an create a raster of x,y dimensions. You point will
> become 1 and all other values will be 0.
> 3) Use the Proximity raster distance gdal function.
> This requires no plugins so it should be easy to create a graphical
> modeler. My favorite way would be to go to strait Python and to call
> the gdal proximity function from my Python script. If you had hundred
> or thousands of these to do, I could develop a Python script that
> could automate the entire thing. Contact me if you have questions.
> Nicolas Cadieux
> On 2021-02-25 12:58 p.m., Fabio Falchi wrote:
>> Dear all,
>> not having received any answer, I repeat the request.
>> I need to speed up the process of obtaining rasters with distances
>> from a single point (or a single lat-lon coordinate) in it. Manually
>> I use this procedure:
>> With a georeferenced raster in a UTM projection I use raster
>> calculator to obtain a raster with all pixels set to zero. Then, with
>> Serval plug-in, I manually set to 1 the value of the pixel in the
>> wanted position (either by using a satellite overlay or by using a
>> point vector layer with the appropriate coordinates). Then I use the
>> proximity function under Raster>Analisys menu.
>> I want to make this via the Graphical Modeler, in order to be able to
>> make the process fast and skip the manual introduction with Serval
>> plug-in. At the very least, I need a mode to put the value 1 in the
>> pixel of the selected null raster in the position givel by lat-lon
>> coordinates.
>> Thank you!
>> Best,
>> Fabio Falchi
>> /USC - Universidade de Santiago de Compostela/
>> /ISTIL - Light Pollution Science and Technology Institute/
>> Il sabato 20 febbraio 2021, 18:04:14 CET, Fabio Falchi
>> <fabio_falchi at yahoo.it> ha scritto:
>> Dear all,
>> from a single point in it. Manually I use this procedure:
>> coordinates.
>> Thank you!
>> Best,
>> Fabio Falchi
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Nicolas Cadieux
> https://gitlab.com/njacadieux
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekresources.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210225/4ca7c9a6/attachment-0001.html>
