[Qgis-user] [EXTERN]Re: Changing SVG Search Paths without GUI on Debian Buster | QGIS 3.10.12
Charles Dixon-Paver
charles at kartoza.com
Tue Jan 5 03:37:19 PST 2021
Awesome! Glad it helped out.
On Tue, 5 Jan 2021 at 13:35, STEINER Andreas <asteiner at eurofunk.com> wrote:
> Hello Charles..
> Thanks a million it worked!! I used you script.
> Best regards,
> *Andreas Steiner*
> *Von:* Charles Dixon-Paver <charles at kartoza.com>
> *Gesendet:* Dienstag, 5. Januar 2021 11:47
> *An:* STEINER Andreas <asteiner at EUROFUNK.COM>
> *Cc:* qgis-user at lists.osgeo.org
> *Betreff:* [EXTERN]Re: [Qgis-user] Changing SVG Search Paths without GUI
> Any number of things can go wrong with file paths, but QGIS allows you to
> embed SVG objects in project files to avoid these problems. If you can open
> the project on your windows environment, where the SVG file path is
> specified you should be able to use the drop down on the "Browse" menu and
> select the embed option, then specify the SVG file to include.
> I also previously wrote a script to automatically embed the svg symbols
> for all layers in a project if you have a lot of layers to update.
> Currently only supports single layer marker (so if you have complex
> symbology it may not work). You may be able to adapt it to your needs
> One issue is that the marker is embedded as a base64 string. This means if
> you have a complex SVG and use the same symbol on multiple layers, it may
> be a bit clunky especially when used on QGIS server. I still think
> investigating the file path issue is worth figuring out, but the embed
> method should help as a quickfix.
> Run from the python QGIS console to take existing svg paths and
> convert them to project-embedded symbol items. Currently only
> supports single symbol and rule style types. Doesn't cater for
> geometry builder elements or other advanced functions.
> import os
> import base64
> def embedSymbol(symbol):
> try:
> layer_type = symbol.layerType()
> if layer_type == 'SvgMarker':
> svg_path = symbol.path()
> if svg_path[:7] == 'base64:':
> print('svg symbol already embedded')
> else:
> encoded_string = ""
> with open(svg_path, "rb") as svg:
> encoded_string = base64.b64encode(svg.read())
> decoded_string = encoded_string.decode("utf-8")
> svg_content = 'base64:' + decoded_string
> symbol.setPath(svg_content)
> print('embedded svg symbol')
> else:
> print('not an svg symbol')
> except Exception as err:
> print(err)
> layers = [layer for layer in QgsProject.instance().mapLayers().values()]
> for layer in layers:
> if layer.type() == QgsMapLayer.VectorLayer:
> try:
> print(layer.name())
> render = layer.renderer()
> render_type = render.type()
> if render_type == 'singleSymbol':
> if hasattr(render.symbol(), 'symbolLayers'):
> for symbol in render.symbol().symbolLayers():
> embedSymbol(symbol)
> else:
> embedSymbol(render.symbol())
> if render_type == 'RuleRenderer':
> rules = render.rootRule()
> rules = rules.children()
> for rule in rules:
> if hasattr(rule.symbol(), 'symbolLayers'):
> for symbol in rule.symbol().symbolLayers():
> embedSymbol(symbol)
> else:
> embedSymbol(rule.symbol())
> print(err)
> I hope that helps
> On Tue, 5 Jan 2021 at 12:35, STEINER Andreas <asteiner at eurofunk.com>
> wrote:
> Hello everyone.
> I tried to load a QGIS Project which was created on windows. In this
> project I used a svg symbol "symbol/blue-marker.svg". In the .qgis file the
> path is also "symbol/blue-marker.svg".
> When I start my qgisserver and request the map there are only this ?
> questions marks because qgis can't find the blue-marker.svg.
> It should look like this:
> I tried to copy the symbol folder with the symbols to /usr/lib/cgi-bin/
> folder where the qgis_mapserv.fcgi file is located. Didn't work.
> Then I tried to copy the symbol folder to the location of the .qgis
> project file. Didn't work.
> I researched a little bit and found a command to show me what the default
> svg paths are:
> python3
> from qgis.core import QgsApplication
> QgsApplication.showSettings()
> 'Application state:\nQGIS_PREFIX_PATH env
> var:\t\t/usr/share/qgis/lib/qgis/server\nPrefix:\t\t\nPlugin
> Path:\t\t\nPackage Data
> Path:\t/usr/share/qgis/lib/qgis/server/share/qgis\nActive Theme
> Path:\t/usr/share/qgis/lib/qgis/server/share/qgis/resources/themes//icons/\nDefault
> Theme Path:\t:/images/themes/default/\nSVG Search Paths:\t\nUser DB
> Path:\t/usr/share/qgis/lib/qgis/server/share/qgis/resources/qgis.db\nAuth
> DB Path:\tqgis-auth.db\n'
> *SVG Search Paths:\t\n*
> From there I know that my SVG Search Paths are empty.
> I can change the variable temporary with:
> QgsApplication.setDefaultSvgPaths(['/usr/share/qgis/svg'])
> but this doesn't help.
> I also tried to execute this command when creating the docker image but
> the SVG Search Paths are also empty after that.
> So in my opinion somewhere this variable can be set but I can't find it,
> also not in the QGIS Environment variables.
> Here is my qgis apache2 config:
> <VirtualHost *:80>
> ServerAdmin webmaster at localhost
> ServerName qgis.demo
> DocumentRoot /var/www/html
> # Apache logs (different than QGIS Server log)
> ErrorLog ${APACHE_LOG_DIR}/qgis.demo.error.log
> CustomLog ${APACHE_LOG_DIR}/qgis.demo.access.log combined
> # Longer timeout for WPS... default = 40
> FcgidIOTimeout 120
> FcgidInitialEnv LC_ALL "en_US.UTF-8"
> FcgidInitialEnv PYTHONIOENCODING UTF-8
> FcgidInitialEnv LANG "en_US.UTF-8"
> # QGIS log (different from apache logs) see
> https://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/ogc_server_support.html#qgis-server-logging
> FcgidInitialEnv QGIS_SERVER_LOG_FILE /var/log/qgis/qgisserver.log
> FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
> #FcgidInitialEnv QGIS_PREFIX_PATH /usr/share/qgis/lib/qgis/server
> FcgidInitialEnv QGIS_PLUGINPATH /opt/qgis-server/plugins
> FcgidInitialEnv QGIS_DEBUG 0
> # default QGIS project
> SetEnv QGIS_PROJECT_FILE /home/qgis/projects/world.qgs
> # QGIS_AUTH_DB_DIR_PATH must lead to a directory writeable by the
> Server's FCGI process user
> FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH "/home/qgis/qgisserverdb/"
> FcgidInitialEnv QGIS_AUTH_PASSWORD_FILE
> "/home/qgis/qgisserverdb/qgis-auth.db"
> # See
> https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/supported_data.html#pg-service-file
> SetEnv PGSERVICEFILE /home/qgis/.pg_service.conf
> FcgidInitialEnv PGPASSFILE "/home/qgis/.pgpass"
> # Tell QGIS Server instances to use a specific display number
> # FcgidInitialEnv DISPLAY ":99"
> # if qgis-server is installed from packages in debian based distros this
> is usually /usr/lib/cgi-bin/
> # run "locate qgis_mapserv.fcgi" if you don't know where
> qgis_mapserv.fcgi is
> ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
> <Directory "/usr/lib/cgi-bin/">
> AllowOverride None
> Options +ExecCGI -MultiViews -SymLinksIfOwnerMatch
> Order allow,deny
> Allow from all
> Require all granted
> </Directory>
> <IfModule mod_fcgid.c>
> FcgidMaxRequestLen 26214400
> FcgidConnectTimeout 60
> </IfModule>
> </VirtualHost>
> Thanks for helping 😊
> Best regards,
> *Andreas Steiner*
> Qgis-user mailing list
> Email secured by Check Point
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210105/cf6cbff1/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210105/cf6cbff1/attachment-0001.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210105/cf6cbff1/attachment-0001.jpg>
