[Qgis-user] How do I clean up this geometry?
Phil Wyatt
phil at wyatt-family.com
Fri Jan 8 23:06:45 PST 2021
I spotted at least one other anomaly
Bottom left of this object has a long sliver that you might want to remove
Cheers
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of qgis-user at stripfamily.net
Sent: Saturday, 9 January 2021 7:28 AM
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] How do I clean up this geometry?
This linked <https://drive.google.com/file/d/1o1KthonUPSZGWp6QImS9btbj799Lv-om/view?usp=sharing> file, proclaimed.zip, is the boundary of the Santa Fe National Forest as supplied by the USFS.
If you focus on this area
There is some problematic geometry. If I do a dissolve I get this:
If I remove the holes, I'm left with this bit of stray boundary:
I then remove that with edit nodes. But the resulting polygon is still not clean - if I try to use the field calculator to add the area (using $area), I get null.
There is bad geometry that I'm not spotting, but how do I find it?
The second linked <https://drive.google.com/file/d/1ul60p0rSdwKcmt6zUivSMIPQHXYc_rcT/view?usp=sharing> file, clean.zip, is the result of the steps above.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/69c319df/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/69c319df/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/69c319df/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/69c319df/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/69c319df/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/69c319df/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/69c319df/attachment-0011.png>
