[Qgis-user] QGIS 3.16 Training Manual - Module 8.2.1 - Intersect features
Wanda Norman
wanda.mnorman2015 at gmail.com
Tue Jan 12 13:46:44 PST 2021
Thank you for the information. I did find that my project projection was
different then the vector analysis so I changed that to match. I also
tried the vector/Geometry tools/Check Validity. It gives me new temporary
layers but I don't understand what to do with them. Sorry, I am trying to
understand - but I feel like I am still missing something.
On Tue, Jan 12, 2021 at 1:18 PM Inna Nogeste <nogeste at outlook.com> wrote:
> The tutorial needs a lot of love to get it to the same level as the User
> Guide 😊 I have a background in documentation but currently don’t have
> time to devote all the time that is required to update the text,
> screengrabs, URLs etc. I’ve encountered more issues today such as WMS and
> WFS URLs/hyperlinks no longer working and more but currently don’t have the
> time to go through any more tutorial pages.
> I’ll do what I can when I can.
> Could updating the tutorial be sponsored if deemed sufficiently important
> to update?
> Regards,
> Inna Nogeste
> *Från: *Alexandre Neto <senhor.neto at gmail.com>
> *Skickat: *den 11 januari 2021 19:44
> *Till: *Inna Nogeste <nogeste at outlook.com>
> *Kopia: *Wanda Norman <wanda.mnorman2015 at gmail.com>; qgis-user
> <qgis-user at lists.osgeo.org>
> *Ämne: *Re: [Qgis-user] QGIS 3.16 Training Manual - Module 8.2.1 -
> Intersect features
> Sure!
> Add a comment on github with @SrNetoChan to mention me.
> Thanks for your help! The training manual needs some love, but most
> resources are directed to the user manual.
> Alexandre Neto
> A segunda, 11/01/2021, 17:37, Inna Nogeste <nogeste at outlook.com> escreveu:
> Hi Alexandre,
> Thanks for your YouTube links, they help alot. I have made alot of notes
> to date as to what should be updated in the QGIS 3.16 Training Manual and
> will gradually add these to Git Hub using your YouTube instructions.
> I’ll let you know when I’ve started so that you can perhaps check that I
> have done it correctly?
> Regards,
> Inna Nogeste
> *Skickat: *den 11 januari 2021 16:17
> Intersect features
> Hello Inna,
> If you want, I can help you make the change yourself :-)
> Or, alternatively, check the following videos to see how you can do it
> QGIS Documentation made easy - Part 1
> https://youtu.be/PCiohDt-OBk
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fyoutu.be%2FPCiohDt-OBk&data=04%7C01%7C%7C155d8d2f90fb42b20c6a08d8b660dd84%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637459874432921891%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=04G8EqKwyjvYTXnFThj8SGKAhJQ2rynb5WSqnwCRIx4%3D&reserved=0>
> - part 1
> https://youtu.be/19Bj0uXcdfU
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fyoutu.be%2F19Bj0uXcdfU&data=04%7C01%7C%7C155d8d2f90fb42b20c6a08d8b660dd84%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637459874432921891%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=41lBo1QfhzS%2FK4GZYWl6FnR2pxNt1I9tEuPIsEuFe2s%3D&reserved=0>
> - part 2
> Thanks
> Alexandre Neto
> On Mon, Jan 11, 2021 at 12:23 PM Inna Nogeste <nogeste at outlook.com> wrote:
> Hi Wanda,
> Looking at my notes for what wasn’t working for me in the Training Manual
> exercises, I see that I needed to make the following change in Step 6.2.8
> using QGIS 3.16 :
> “Need to set the processing option to Skip (Ignore) invalid geometry.
> Seemed to be a problem with the buildings_34s layer? Changed this option
> for both input and compare layers and it worked.”
> I hope this helps!
> Regards,
> Inna Nogeste
> Skickades från E-post
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgo.microsoft.com%2Ffwlink%2F%3FLinkId%3D550986&data=04%7C01%7C%7C155d8d2f90fb42b20c6a08d8b660dd84%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637459874432931885%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=0XxXTPmVlfvVqKpthep1zUOQ%2FhvH%2B%2FigZUEn4QmBpA4%3D&reserved=0>
> för Windows 10
> *Från: *Wanda Norman <wanda.mnorman2015 at gmail.com>
> *Skickat: *den 8 januari 2021 15:31
> *Kopia: *qgis-user <qgis-user at lists.osgeo.org>
> Intersect features
> I am getting the same error in the training module for lesson 6.2.9. I
> have done the lesson twice thinking I had missed a step - but get to the
> same point of extracting the buildings and get the error message.
> I am using QGIS 3.1 with Windows 10 on my HP laptop.
> Thanks!
> Wanda Norman
> On Thu, Jan 7, 2021 at 12:23 PM Inna Nogeste <nogeste at outlook.com> wrote:
> I’m working through the training manual and completed all the preceding
> modules and their output files.
> When I get to Module 8.2.1
> https://docs.qgis.org/3.16/en/docs/training_manual/complete_analysis/analysis_combination.html#moderate-ty
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.qgis.org%2F3.16%2Fen%2Fdocs%2Ftraining_manual%2Fcomplete_analysis%2Fanalysis_combination.html%23moderate-ty&data=04%7C01%7C%7C155d8d2f90fb42b20c6a08d8b660dd84%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637459874432941878%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=ECkQQF5rMG1znxqXjpHoFBL4oVHWQ3540a%2F8kQC5oQc%3D&reserved=0>
> to intersect my previous output files I get an error message when I run
> the Intersection tool that a feature in my Overlay layer ’has invalid
> geometry. Please fix the geometry or change the Processing setting to the
> “Ignore invalid input features” option.’
> The overlay layer is a polygonized vector layer createdin a previous
> modeul in the training manual from a raster layer.
> The invalid geometry in the polygonized layer represents 1 individual cell
> in the original raster layer. Changing the Processing setting to ”Skip
> (Ignore) Features with Invalid Geometries” doesn’t help and outputs an
> empty layer.
> Has anyone else had problems with this module and the layer files created
> in previous modules?
> I’ve noted that the original SRTM_41_19.TIF exercise data is in EPSG 32733
> and not EPSG 32734 as per the other exercise (vector) data and this causes
> issues when you get to Module 8.
> I’m currently documenting discrepancies that I’m finding in the training
> manual and am assuming that I can eventually add them to
> https://github.com/qgis/QGIS-Documentation/issues?q=is%3Aissue+is%3Aopen+label%3AEasy
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fqgis%2FQGIS-Documentation%2Fissues%3Fq%3Dis%253Aissue%2Bis%253Aopen%2Blabel%253AEasy&data=04%7C01%7C%7C155d8d2f90fb42b20c6a08d8b660dd84%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637459874432941878%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=vwC8RM34ZvQEWlbwX5m%2Bvk%2FyV0KS9corUNkhB9Xu1YI%3D&reserved=0>
> Regards,
> Inna Nogeste
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgo.microsoft.com%2Ffwlink%2F%3FLinkId%3D550986&data=04%7C01%7C%7C155d8d2f90fb42b20c6a08d8b660dd84%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637459874432951876%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=OjoWeuHegrQL3ULdoQQoiv9mC%2FxcbLPEvwK1ZOcUQKA%3D&reserved=0>
> för Windows 10
> Qgis-user mailing list
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7C%7C155d8d2f90fb42b20c6a08d8b660dd84%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637459874432951876%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=pFwxj%2BpJlhCn%2BydFAx%2BwFayxwDYgTnZVYElc6nWcmE0%3D&reserved=0>
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7C%7C155d8d2f90fb42b20c6a08d8b660dd84%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637459874432961862%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=bFrtu16pXdM8EFg64Y9%2Bg4asOBaVIbAyeCHvFv%2B6N%2Fc%3D&reserved=0>
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7C%7C155d8d2f90fb42b20c6a08d8b660dd84%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637459874432971864%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=IdQzajrAHp4oxVcxXpld29ctU29WGTAgsvMYzo8aoN4%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210112/f790dfe5/attachment-0001.html>
