[Qgis-user] Training manual - 9.1.3. Configuring Additional Plugin Repositories
    Alexandre Neto
    senhor.neto at gmail.com
    Wed Jan 13 05:04:56 PST 2021
If you can, please create an issue on github suggesting the corrections.
A terça, 12/01/2021, 18:15, Inna Nogeste <nogeste at outlook.com> escreveu:
> I’ve seen that most of the plugins are in the repository, this is an
> example in the tutorial which could be deleted, else include a source which
> has plugins not included in the repository if it is important to show this
> stage.
> Regards,
> Inna Nogeste
> *Från: *Alexandre Neto <senhor.neto at gmail.com>
> *Skickat: *den 11 januari 2021 19:45
> *Till: *Inna Nogeste <nogeste at outlook.com>
> *Kopia: *qgis-user <qgis-user at lists.osgeo.org>
> *Ämne: *Re: [Qgis-user] Training manual - 9.1.3. Configuring Additional
> Plugin Repositories
> I think most of the plugins are now available on qgis official repository.
> Alexandre Neto
> A segunda, 11/01/2021, 17:48, Inna Nogeste <nogeste at outlook.com> escreveu:
> QGIS 3.16 – Faunalia plugins
> This step teaches how to configure a plugin respository from Faunalia
> https://docs.qgis.org/3.16/en/docs/training_manual/qgis_plugins/fetching_plugins.html#basic-fa-configuring-additional-plugin-repositories
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.qgis.org%2F3.16%2Fen%2Fdocs%2Ftraining_manual%2Fqgis_plugins%2Ffetching_plugins.html%23basic-fa-configuring-additional-plugin-repositories&data=04%7C01%7C%7C65d4e9610bc34f9e2ddc08d8b6610ede%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637459875261382968%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=8BhXkLcU9jC%2Bv2KhbIcHq90RnXZUX9fw2NsD7E27PIw%3D&reserved=0>
> however I’m getting the following error message:
> “Error reading repository:Fanualia
> Server response is 200 OK, but doesn’t contain plugin metadata. This is
> most likely caused by a proxy or wrong repository URL. You can configure
> proxy settings in QGIS Options.”
>  The URL in the training manual no longer exists and the plugins are
> located here instead:
> https://www.faunalia.eu/en/dev/plugins
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.faunalia.eu%2Fen%2Fdev%2Fplugins&data=04%7C01%7C%7C65d4e9610bc34f9e2ddc08d8b6610ede%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637459875261382968%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=ydmeMkEL6ROEYNDMa0cLldIuCTIZdlnDlicz1myU3uE%3D&reserved=0>
>  Does anyone (from Faunalia?) know what the URL should be or what needs to
> be edited in the Proxy settings for this to work? I’ll then be able to edit
> this step in the doucmentation GitHub with the correct info.
>  Regards,
> Inna Nogeste
> Qgis-user mailing list
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7C%7C65d4e9610bc34f9e2ddc08d8b6610ede%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637459875261392960%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=8rbl3FPVA%2BNvXh4y%2FthOyIYRci3ybvpqwPFpcrZsoso%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210113/e8e63927/attachment.html>
