[Qgis-user] How to use QgsProcessingLayerPostProcessorInterface?
Etienne Trimaille
etienne.trimaille at gmail.com
Wed Jan 20 16:25:29 PST 2021
Can you try that?
class Renamer(QgsProcessingLayerPostProcessorInterface): instance =
None def postProcessLayer(self, layer, context, feedback):
layer.setName('DiffLayer') @staticmethod def create() ->
'Renamer': Renamer.instance = Renamer() return
Renamer.instance
In your processAlgorithm method() :
context.layerToLoadOnCompletionDetails(
data[layer].id() ).setPostProcessor(
Renamer.create() )
Le jeu. 21 janv. 2021 à 03:14, <qgis-user at stripfamily.net> a écrit :
> I thought QgsProcessingLayerPostProcessorInterface might be a solution to
> my earlier question about renaming the output layer of Processing script.
> I derive a class and overload postProcessLayer:
> class Renamer (QgsProcessingLayerPostProcessorInterface):
> print('Renaming layer in post-processor')
> Near the end of my processAlgorithm implementation I add:
> details = context.LayerDetails(dest_id,context.project())
> details.setPostProcessor(Renamer())
> where dest_id is the value returned by parameterAsSink
> The postProcessLayer method does not appear to run (no output is produced
> by the print statement) and the layer is added, but the name is unchanged.
> I'm not sure if I'm setting up the post process wrong, or not fetching the
> right LayerDetails object.
> Any pointer to how this should be used or an example of its use would be
> appreciated.
> Thanks
> David
> PS - I also tried the postProcessAlgorithm of the QgsProcessingAlgorithm
> class, but the layer hasn't been added yet when the method is called. I
> wonder if I'll have the same problem with the layer post processor?
> PPS I tried postProcess, but it doesn't appear to get called as far as I
> can tell. Not sure why.
> def postProcess(self, context, feedback):
> print('Number of layers = ' +
> str(len(QgsProject.instance().mapLayers())))
> print("PostProcess completed")
> feedback.pushInfo(1) # This line should generate an error since
> pushInfo expects a string, but no error is thrown
> return {self.OUTPUT: self.dest_id}
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210121/c66a1e01/attachment-0001.html>
