[Qgis-user] saving all temporary layers?
Michael Dufty
MDufty at mbsenvironmental.com.au
Thu Jan 21 21:13:42 PST 2021
Not exactly what you are asking for, so it may not suit, but I find the “memory layer saver” plugin invaluable.
When using this memory layers are not lost when you close QGIS
The plugin description says
“Makes layers with memory data providers persistent
so that they are restored when a project is closed and reopened.
The memory provider data is saved in a portable binary format (QDataStream)
that is saved with extension .mldata alongside the project file.”
I’m not sure if the .mldata file is useful as an export format.
It also does not seem to work with temporary raster files.
You can drag and drop memory layers from one QGIS instance to another (at least in 3.16). They will then persist separately in both QGIS files if you have the memory layer saver plugin installed.
Michael Dufty
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of David Strip
Sent: Friday, 22 January 2021 2:42 AM
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] saving all temporary layers?
Before I write my own, does anyone have a script to share (processing or otherwise) that saves all temporary layers in a project, preferably to a geopackage?
Thanks
David
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210122/75ea946d/attachment.html>
