[Qgis-user] Snapping tools really slow
Philip Barlow
philipb at pembrokeshirecoast.org.uk
Fri Jan 22 05:38:40 PST 2021
Hi Paul,
What sort of database are you using? MSSQL or Postgres?
We're on Postgres13 and PostGIS 3.0. A quick test with QGIS 3.10.14 digitising to OSMM... there is a small delay but its only around a second or two. You may have a larger extent than me in your database though? Mine is just the whole of the County of Pembrokeshire. I haven't tried 3.16 to see if there is any noticeable difference.
Regards
Phil
-----Original Message-----
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Paul Wittle
Sent: 22 January 2021 08:10
To: Julien Cabieces <julien.cabieces at oslandia.com>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Snapping tools really slow
It might be best if I screen record you a video of it loading so you can see the performance issue as it is always difficult to discuss in text. I'll have to send that to you offline from this thread as I believe videos aren't supported by this group.
We are snapping to Ordnance Survey MasterMap because we work in the public sector and are permitted to do so for council business. Depending on licencing you may not be able to access the same level of OS data as you would probably have to pay for it (assuming your company is private) so I guess that would not be helpful in terms of replicating the issue. That said; I also tried it using the OS Maps API (WFS) and it was also slow so OS may be able to share that with you for test purposes.
In the older version 3.10 the progress bar always disappeared for some reason so it appeared to just hand whilst the index builds. In the new version a blue bar appears at the bottom but it is not a loading bar it is the one you get when the application doesn't know how long is left. I tried to stop the process because it was long running and it said 'Indexing' was running did I want to try and stop the process so I'm pretty sure it is the indexing that is not working for some reason.
Is there a way to pre-build the snapping index?
It works fine for smaller layers, things we create etc. If I can resolve this one layer then all my problems go away so we would be really happy to pre-cache the snapping index if that is possible.
Thanks,
Paul
From: Julien Cabieces <julien.cabieces at oslandia.com>
Sent: 22 January 2021 05:32
To: Paul Wittle <P.Wittle at dorsetcc.gov.uk>
I made quick tests with some dataset and I failed to see any performance issues.
Could you create an issue with some data sample and project?
Is it the index building that take a long time (there is a progress bar displayed at the bottom of the map close to the mouse coordinate information while index is currently building) or is it when you move your cursor on the map that the snaping information takes time to appear. Or is it when you pan the map?
You can enable snapping for specific range of scale, avoiding building index at very large scale where snapping is useless.
Regards,
Julien
> Hi,
> I've been using version 3.10 and 3.16 and I notice that enabling snapping is extremely slow and oddly significantly slower on 3.16 than 3.10. We thought it might be downloading the dataset on screen but discovered the data is back from the database within seconds and the delay is because QGIS is building an index.
> Why is it so inefficient and is there anything that can be done to get better performance?
> It is really slow and we are trying to transfer users from MapInfo / ESRI so they will not like the performance at the moment.
> To be clear the data has a primary key, spatial indices and all is of good quality. As I say the data downloads and displays within seconds on the map; is it because I've selected snapping to segment as well as vertex?
> Thanks,
> Paul Wittle
> [cid:image001.jpg at 01D6F016.C23D1CA0]<https://www.dorsetcouncil.gov.uk/
> Business Solutions Analyst (GIS)
> ICT Operations
> Dorset Council
> 01305 228473
> <tel:01305%20228473%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20
> %20%20%20> dorsetcouncil.gov.uk<https://www.dorsetcouncil.gov.uk>
> [cid:image002.png at 01D6F016.C23D1CA0]<https://www.facebook.com/DorsetCo
> uncilUK>
> [cid:image003.png at 01D6F016.C23D1CA0]<https://instagram.com/DorsetCounc
> ilUK>
> [cid:image004.png at 01D6F016.C23D1CA0]<https://twitter.com/DorsetCouncil
> UK>
> This e-mail and any files transmitted with it are intended solely for
> the use of the individual or entity to whom they are addressed. It may
> contain unclassified but sensitive or protectively marked material and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All
> traffic may be subject to recording and/or monitoring in accordance
> with relevant legislation. Any views expressed in this message are
> those of the individual sender, except where the sender specifies and
> with authority, states them to be the views of Dorset Council. Dorset
> Council does not accept service of documents by fax or other
> electronic means. Virus checking: Whilst all reasonable steps have
> been taken to ensure that this electronic communication and its
> attachments whether encoded, encrypted or otherwise supplied are free
> from computer viruses, Dorset Council accepts no liability in respect
> of any loss, cost, damage or expense suffered as a result of accessing
> this message or any of its attachments. For information on how Dorset
> Council processes your information, please see
> www.dorsetcouncil.gov.uk/416433
> Qgis-user mailing list
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supp lied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/416433 _______________________________________________
Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
The Authority is happy to communicate in Welsh or English
Website www.pembrokeshirecoast.wales
Follow us on Twitter
Join us on Facebook
Watch us on Youtube
Look at us on Flickr
This email and any attached files should only be read by those persons to whom
they are addressed and be used by them only for their intended purpose.
If you are not the intended recipient please destroy all copies and inform the
sender by return email.
Please note that the contents of this email may be subject to public disclosure
under the Freedom of Information Act 2000 and therefore the confidentiality of
this message and any reply cannot be guaranteed.
Click here to view PCNPA Privacy Notice Keeping your Information Safe
For further information on the PCNPA please visit our website at www.pembrokeshirecoast.wales
Please consider the environment before printing this email.
Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac unrhyw ffeiliau sydd
ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio at y diben y bwriadwyd hwy.
Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech gystal â dinistrio pob copi a rhoi
gwybod i'r anfonwr gyda throad yr e-bost.
Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod cael ei ddatgelu i'r cyhoedd o
dan Deddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu cyfrinachedd y neges hon
nac unrhyw ateb.
Cliciwch yma i weld Hysbysiad Preifatrwydd APCAP - Cadw eich Gwybodaeth yn Ddiogel
Am ragor o wybodaeth am APCAP ymwelwch â'n gwefan ar www.arfordirpenfro.cymru
Ystyrier yr amgylchedd cyn argraffu'r e-bost hwn os gwelwch yn dda.
