[Qgis-user] Polygons Dissolve
Charles Dixon-Paver
charles at kartoza.com
Tue Jan 26 08:31:36 PST 2021
Yes you can use the aggregate processing tool.
You can use a variety of aggregation functions to get the required outputs,
but the tool configuration may vary on input data.
If the tool gives you errors, the usual culprit is data type errors. QGIS
is very clever though, and you can use an expression to preprocess the
field input, and if you specify the output field type it will try to cast
it for you during processing.
Example screenshot: https://imgur.com/a/vPohdLd
In this example I take an input field and convert it to a string value,
concatenate the inputs for all matching geometries into a single field, and
outputs the value as an integer.
Hope that helps.
Regards
On Tue, 26 Jan 2021 at 18:03, krishna Ayyala <ayyalakrishna at gmail.com>
wrote:
> I have a polygons shapefile as shown below.
> [image: image.png]
> Is it possible to dissolve these polygons and get a resultant shapefile
> with an attribute table such as below?i.e. it should have only one
> polygonName and all of its associated fields.
> PolygonName Field1 Field2
> A 1 2
> B 3 4
> C 5 6
> D 7 8
> E 9 10
> F 11 12
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210126/82fd4ab5/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210126/82fd4ab5/attachment.png>
