[Qgis-user] Editing attributes in embedded forms
    Pekka Sarkola
    pekka at gispo.fi
    Wed Jun  2 23:23:45 PDT 2021
You repeat this "ERROR: column "sample_point_fid_seq" does not exist"
-problem with:
Create very simple table to PostGIS (choose your own CRS):
CREATE TABLE IF NOT EXISTS sample_point
    fid integer NOT NULL GENERATED ALWAYS AS IDENTITY,
    wkb_point geometry(Point,3067),
    name varchar,
    CONSTRAINT sample_point_pk PRIMARY KEY (fid)
Add table to QGIS. Editing works, without errors.
If you tick on from project properties: "Evaluate default values on
provider side", error will happen:
2021-06-03T09:22:31     WARNING    Erroneous query: SELECT
nextval("sample_point_fid_seq"::regclass) returned 7 [ERROR: column
             LINE 1: SELECT nextval("sample_point_fid_seq"::regclass)
Rgs,
Pekka
Pekka Sarkola
Gispo Oy
pekka.sarkola at gispo.fi   - GSM +358 40 725 2042
www.gispo.fi – www.paikkatieto.com
to 3. kesäk. 2021 klo 8.47 Pekka Sarkola (pekka at gispo.fi) kirjoitti:
> Hi Alexandre et al,
> I re-create a database (sample one), create a new QGIS project, add layers
> => same error. Maybe I open an issue in Github and I can share more SQL and
> snapshots.
> Rgs,
> Pekka
> Pekka Sarkola
> Gispo Oy
> ti 1. kesäk. 2021 klo 16.36 Alexandre Neto (senhor.neto at gmail.com)
> kirjoitti:
>> From that last error...
>> Are you sure your table was not changed after being loaded to QGIS? It
>> seems to expect a sequence that no longer exists.
>> Alexandre Neto
>> A terça, 1/06/2021, 12:22, Pekka Sarkola <pekka at gispo.fi> escreveu:
>>> Hi Andreas,
>>> Trasnsactions groups are enabled: editing is working (not in embedded
>>> forms) as expected.
>>> If I enable "Evaluate default values.."-option, I will get error:
>>> 2021-06-01T14:11:44     WARNING    Erroneous query: SELECT
>>> Primary key of the geometry table is "fid" and it has been defined as
>>> IDENTITY column (fid integer NOT NULL GENERATED ALWAYS AS IDENTITY (
>>> INCREMENT 1 START 1 MINVALUE 1 MAXVALUE 2147483647 CACHE 1 ).
>>> I presume this evaluation of the default values is not the solution for
>>> this case.
>>> Rgs,
>>> Pekka
>>> Pekka Sarkola
>>> Gispo Oy
>>> ti 1. kesäk. 2021 klo 11.10 Andreas Neumann (a.neumann at carto.net)
>>> kirjoitti:
>>>> Hi Pekka,
>>>> Have you enabled the  transaction mode in your project?
>>>> See menu "Project" --> "Properties" --> "Data Sources".
>>>> I usually enable all three check boxes:
>>>> - Automatically create transaction groups where possible
>>>> - Evaluate default values on provider side
>>>> - Trust project when data source has no metadata
>>>> The transaction mode allows to edit all layers from the same data base
>>>> connection (needs identical db connection string and credentials) and -
>>>> together with "evaluate default values on provider side" - immediately
>>>> retrieves primary keys from the DB, so that you can link objects
>>>> immediately, without having to save first.
>>>> Greetings,
>>>> Andreas
>>>> On 2021-06-01 09:55, Pekka Sarkola wrote:
>>>> Hi folks!
>>>> I have a problem editing feature attributes in embedded forms. Data is
>>>> stored in PostGIS and I have a simple 1:1 relationship with the geometry
>>>> table and an additional attribute table. QGIS version is 3.18.3 on Ubuntu.
>>>> I have created a custom form with a drag-and-drop designer. I can edit
>>>> additional attribute table attributes in embedded form, but those edits are
>>>> not stored anywhere. I have to open a separate form and then edit attribute
>>>> values of the related attribute table. This is quite annoying for the end
>>>> user.
>>>> Any suggestions? Or should I write a better description to the Github?
>>>> Rgs,
>>>> Pekka
>>>> Pekka Sarkola
>>>> Gispo Oy
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210603/6b1b1e36/attachment.html>
