[Qgis-user] Editing attributes in embedded forms
    Alessandro Pasotti
    apasotti at gmail.com
    Thu Jun  3 01:14:02 PDT 2021
Is this related to https://github.com/qgis/QGIS/issues/32898 ?
On Thu, Jun 3, 2021 at 8:24 AM Pekka Sarkola <pekka at gispo.fi> wrote:
> Hi,
> You repeat this "ERROR: column "sample_point_fid_seq" does not exist"
> -problem with:
> Create very simple table to PostGIS (choose your own CRS):
> CREATE TABLE IF NOT EXISTS sample_point
>     fid integer NOT NULL GENERATED ALWAYS AS IDENTITY,
>     wkb_point geometry(Point,3067),
>     name varchar,
>     CONSTRAINT sample_point_pk PRIMARY KEY (fid)
> Add table to QGIS. Editing works, without errors.
> If you tick on from project properties: "Evaluate default values on
> provider side", error will happen:
> 2021-06-03T09:22:31     WARNING    Erroneous query: SELECT
> nextval("sample_point_fid_seq"::regclass) returned 7 [ERROR: column
>              LINE 1: SELECT nextval("sample_point_fid_seq"::regclass)
> Rgs,
> Pekka
> Pekka Sarkola
> Gispo Oy
> pekka.sarkola at gispo.fi   - GSM +358 40 725 2042
> www.gispo.fi – www.paikkatieto.com
> to 3. kesäk. 2021 klo 8.47 Pekka Sarkola (pekka at gispo.fi) kirjoitti:
>> Hi Alexandre et al,
>> I re-create a database (sample one), create a new QGIS project, add
>> layers => same error. Maybe I open an issue in Github and I can share more
>> SQL and snapshots.
>> Rgs,
>> Pekka
>> Pekka Sarkola
>> Gispo Oy
>> ti 1. kesäk. 2021 klo 16.36 Alexandre Neto (senhor.neto at gmail.com)
>> kirjoitti:
>>> From that last error...
>>> Are you sure your table was not changed after being loaded to QGIS? It
>>> seems to expect a sequence that no longer exists.
>>> Alexandre Neto
>>> A terça, 1/06/2021, 12:22, Pekka Sarkola <pekka at gispo.fi> escreveu:
>>>> Hi Andreas,
>>>> Trasnsactions groups are enabled: editing is working (not in embedded
>>>> forms) as expected.
>>>> If I enable "Evaluate default values.."-option, I will get error:
>>>> 2021-06-01T14:11:44     WARNING    Erroneous query: SELECT
>>>> Primary key of the geometry table is "fid" and it has been defined as
>>>> IDENTITY column (fid integer NOT NULL GENERATED ALWAYS AS IDENTITY (
>>>> INCREMENT 1 START 1 MINVALUE 1 MAXVALUE 2147483647 CACHE 1 ).
>>>> I presume this evaluation of the default values is not the solution for
>>>> this case.
>>>> Rgs,
>>>> Pekka
>>>> Pekka Sarkola
>>>> Gispo Oy
>>>> ti 1. kesäk. 2021 klo 11.10 Andreas Neumann (a.neumann at carto.net)
>>>> kirjoitti:
>>>>> Hi Pekka,
>>>>> Have you enabled the  transaction mode in your project?
>>>>> See menu "Project" --> "Properties" --> "Data Sources".
>>>>> I usually enable all three check boxes:
>>>>> - Automatically create transaction groups where possible
>>>>> - Evaluate default values on provider side
>>>>> - Trust project when data source has no metadata
>>>>> The transaction mode allows to edit all layers from the same data base
>>>>> connection (needs identical db connection string and credentials) and -
>>>>> together with "evaluate default values on provider side" - immediately
>>>>> retrieves primary keys from the DB, so that you can link objects
>>>>> immediately, without having to save first.
>>>>> Greetings,
>>>>> Andreas
>>>>> On 2021-06-01 09:55, Pekka Sarkola wrote:
>>>>> Hi folks!
>>>>> I have a problem editing feature attributes in embedded forms. Data is
>>>>> stored in PostGIS and I have a simple 1:1 relationship with the geometry
>>>>> table and an additional attribute table. QGIS version is 3.18.3 on Ubuntu.
>>>>> I have created a custom form with a drag-and-drop designer. I can edit
>>>>> additional attribute table attributes in embedded form, but those edits are
>>>>> not stored anywhere. I have to open a separate form and then edit attribute
>>>>> values of the related attribute table. This is quite annoying for the end
>>>>> user.
>>>>> Any suggestions? Or should I write a better description to the Github?
>>>>> Rgs,
>>>>> Pekka
>>>>> Pekka Sarkola
>>>>> Gispo Oy
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210603/f8e1173f/attachment.html>
