[Qgis-user] Keyframing layers
    Charles Dixon-Paver
    charles at kartoza.com
    Thu Jun  3 06:50:51 PDT 2021
Have you tried using a map theme? Style and activate your layers in the
layers panel/ toc, use the "eyeball" dropdown to save that configuration as
a named map theme, then apply your theme to the 3D map view.
On Thu, 3 Jun 2021 at 15:27, Drew French <fullboarfarm at gmail.com> wrote:
> Am I correct in understanding that saving a keyframe in a 3D View does not
> keyframe the visible layers, i.e keyframing has no effect on visible
> vector/raster/mesh layers? I ask because I would like to keyframe a
> sequence that includes turning various layers off and on at different
> times. Has anyone been able to do this within QGIS? Thank you for your
> thoughts.
> Drew French
> (715) 986-8088
> www.ecologicaldesign.land
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210603/7c0ef1ea/attachment.html>
