[Qgis-user] Google earth historical images
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Thu Jun  3 08:42:17 PDT 2021
Thank Charles, this is interesting.  Unless I am mistaken thought, the
google Earth engine will not give me the images normally seen on Google
Earth as those are proprietary data that we cannot normally use.  Google
Earth engine (unless I am mistaken)  gives us what is normally openly
accessible.  In this case, I just need the high rez pretty picture and
not the actually usable satellite imagery.  I will check out the link as
well as the Google Earth Engine.  I have used it in the past I'm a bit
shaky in java script...  Too busy learning other stuff!
Thanks again!
Nicolas
On 2021-06-03 9:18 a.m., Charles Dixon-Paver wrote:
> Not quite the same as the plugins/ process you mentioned, but you use
> this plugin to integrate the GEE python API in QGIS:
> https://gee-community.github.io/qgis-earthengine-plugin/
> <https://gee-community.github.io/qgis-earthengine-plugin/>
> I've never tried what you are asking, but it's probably where I would
> start.
> On Thu, 3 Jun 2021 at 15:14, Nicolas Cadieux
> <njacadieux.gitlab at gmail.com <mailto:njacadieux.gitlab at gmail.com>> wrote:
>     Hi,
>     Is there a plugin similar to quickmap, or a method that can permit
>     us to download the historical imagery from Google Earth?  The
>     default (latest) image for my region is 2012 but I would need to
>     look at 2011.
>     If worse comes to worse, I know I can georeference the saved
>     images from Google Earth.  I am aware of the GE license
>     limitations so there is no need to address them here.
>     Thanks for your help!
>     Nicolas Cadieux
>     https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210603/cb82b4c9/attachment.html>
