[Qgis-user] Compiling messages Qgis 3.18.3
    APM
    apschwimmer at apmland.de
    Wed Jun  9 07:16:05 PDT 2021
Dear All,
on a Debian Bullseye system I compiled Qgis 3.18.3 following
https://github.com/qgis/QGIS/blob/master/INSTALL.md
<https://github.com/qgis/QGIS/blob/master/INSTALL.md>.
After a 'make install' I received sevaral similar messages, please see a
cut below:
Could not execute: INSERT INTO tbl_srs(srs_id,
description,projection_acronym,ellipsoid_acronym,parameters,srid,auth_name,auth_id,is_geo,deprecated)
VALUES (63422, 'NAD27 (CRS27)','longlat',NULL,'+proj=longlat
+datum=NAD27 +no_defs',520003422,'OGC','CRS27',1,0) [NOT NULL constraint
failed: tbl_srs.ellipsoid_acronym/NOT NULL constraint failed:
tbl_srs.ellipsoid_acronym]
VALUES (63423, 'NAD83 (CRS83)','longlat',NULL,'+proj=longlat
+datum=NAD83 +no_defs',520003423,'OGC','CRS83',1,0) [NOT NULL constraint
Do you know, what is wrong? There seems to be something like a sql error?
Thank you!
Kind regards
Piet
