[Qgis-user] Compiling messages Qgis 3.18.3
    APM
    apschwimmer at apmland.de
    Thu Jun 10 04:23:21 PDT 2021
Hello Andrea,
yes, this is the case!
All blocks of the message contains
"NOT NULL constraint failed:"
Kind regards
Piet
Am 10.06.21 um 11:11 schrieb Andrea Giudiceandrea:
> APM wrote
>> After a 'make install' I received sevaral similar messages, please see a
>> cut below:
>> Could not execute: INSERT INTO tbl_srs(srs_id,
>> description,projection_acronym,ellipsoid_acronym,parameters,srid,auth_name,auth_id,is_geo,deprecated)
>> VALUES (63422, 'NAD27 (CRS27)','longlat',NULL,'+proj=longlat
>> +datum=NAD27 +no_defs',520003422,'OGC','CRS27',1,0) [NOT NULL constraint
>> failed: tbl_srs.ellipsoid_acronym/NOT NULL constraint failed:
>> tbl_srs.ellipsoid_acronym]
> Hi Pet,
> are all the messages referring to "NOT NULL constraint failed:
> tbl_srs.ellipsoid_acronym" or are there other types of errors?
> Regards.
> Andrea
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
