[Qgis-user] How to filter shape or oracle layer
Richard McDonnell richard.mcdonnell at opw.ie
Thu Jun 10 04:57:49 PDT 2021
Dario,
To run a spatial query you need to use Select by Location or extract by location. This assumes that you have two different layers.
I don’t believe it will do this for a single layer with the above.
Are you trying to use the geometry Generator?
Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
Sent: 10 June 2021 12:41
To: Richard McDonnell <richard.mcdonnell at opw.ie>
Cc: QGIS User List <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] How to filter shape or oracle layer
Hi Richard,
The issue is that I tried to write down:
intersects( $geometry, geometry( get_feature( layer, attributeField, value ) ))
But nothing happens :(
_
Il giorno 10 giu 2021, alle ore 12:21, Richard McDonnell <richard.mcdonnell at opw.ie<mailto:richard.mcdonnell at opw.ie>> ha scritto:
Hi Dario,
If you right click on any Vector Layer and select Filter you can filter as you wish.
Regards,
Richard
FRM Data Management
https://gov.ie/opw
From: Qgis-user <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> On Behalf Of Dario C
Sent: 09 June 2021 12:33
To: QGIS User List <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
Subject: [Qgis-user] How to filter shape or oracle layer
Hi, is there any way to filter a layer (both shape and oracle) using a spatial query?
(I would like to load/view only what it is inside a range of value of a proper "field")
Thanks
Please note that the existing 01-6476XXX / 046-9426XXX numbering ranges will no longer be available after 30th April 2021.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210610/506bdd33/attachment-0001.html>
