[Qgis-user] How to filter shape or oracle layer
Dario C
dario955i at gmail.com
Thu Jun 10 06:33:44 PDT 2021
Hi Andrea,
I'm using "Provider Specific Filter expression". I don't even know how to
use "Provider Feature Filter".
And yes, I've replaced layer, filed and value with the real name.
thanks
Il giorno gio 10 giu 2021 alle ore 15:01 Andrea Giudiceandrea <
andreaerdna at libero.it> ha scritto:
> Dario C wrote
> > The issue is that I tried to write down:
> > intersects( $geometry, geometry( get_feature( layer, attributeField,
> value
> > But nothing happens :(
> Hi Dario,
> are you using the above expression as "Provider Feature Filter"/"Provider
> Specific Filter Expression"?
> Have you substituted "layer", "attributeField" and "value" with the actual
> layer name, attribute field name and value of the field following the
> get_feature() syntax?
> https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/functions_list.html#get-feature
> Regards.
> Andrea
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210610/be54eef5/attachment-0001.html>
