[Qgis-user] Working with GIT in case of changes in src
Nicolas Boisteault
nboisteault at 3liz.com
Mon Jun 14 00:28:02 PDT 2021
Hello Piet,
You can keep your local change until it is merged in original source code.
If you want to update to last changes in original code, you can :
git stash
git pull
git stash apply
Regards
Le 14/06/2021 à 09:14, APM a écrit :
> Dear List,
> my question is not related to Qgis directly, but I would be glad, if
> you could help me.
> On a Debian Bullseye I compiled Qgis and changed the file
> ....src/core/proj/qgscoordinatereferencesystem.cpp
> manually, because the orginal file contains a bug, which is already
> reported.
> I think, this bugs will be corrected in the orginal source files soon.
> But I do not know when.
> If I start 'git pull', git ask me to 'commit' or to 'stash' my changes.
> Make it sense to keep my manual changes until the change is in the
> orginal source code?
> Could this 'keep' cause other errors, because my local source files do
> not fit to the branch anymore?
> Kind regards
> Piet
> Qgis-user mailing list
