[Qgis-user] Fwd: Compiling messages Qgis 3.19.0
Andrea Giudiceandrea andreaerdna at libero.it
Tue Jun 15 00:59:56 PDT 2021
Richard Duivenvoorde wrote
> Could not execute: INSERT INTO tbl_srs(srs_id,
> description,projection_acronym,ellipsoid_acronym,parameters,srid,auth_name,auth_id,is_geo,deprecated)
> VALUES (63321, 'Timbalai 1948 / RSO Sarawak LSD
> (m)','omerc','omerc','+proj=omerc +no_uoff +lat_0=4 +lonc=115
> +alpha=53.3158204722222 +gamma=53.1301023611111 +k=0.99984 +x_0=2000000
> +y_0=5000000 +ellps=evrstSS +towgs84=-679,669,-48,0,0,0,0 +units=m
> +no_defs',520003321,'EPSG','29874',0,0) [UNIQUE constraint failed:
> tbl_srs.srs_id/UNIQUE constraint failed: tbl_srs.srs_id]
> 1 CRSs could not be updated.
> Others can confirm? (and eventually @Andrea: would this be fixable ;-) )
Hi Richard,
this issue was already fixed (as confirmed by Saulteau and Piet) with
https://github.com/qgis/QGIS/pull/43694, thereafter superseded by
https://github.com/qgis/QGIS/pull/43712 which has not yet been merged in
master.
Bet regards.
Andrea
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
