[Qgis-user] Geometry generator - reduce line
    Dario C
    dario955i at gmail.com
    Thu Jun 17 06:59:13 PDT 2021
I solved the second part (label) using geometries generator also in the
location of the label
using the same geometry of the line
make_line( start_point( $geometry), translate( centroid( $geometry),
$length/10, $length/10), end_point($geometry))
problem with REDUCE geometry still remains...
Il giorno gio 17 giu 2021 alle ore 15:52 Dario C <dario955i at gmail.com> ha
scritto:
> Hi,
> I'm trying to do an arc starting from a simple line.
> I'm using geometry generator with this code:
> and it is working well.
> I'd like to have shorter line, so I started considering extend function
> with negative paramtere, but it does not work:
> extend(make_line( start_point( $geometry), translate( centroid(
> $geometry), $length/10, $length/10), end_point($geometry)),-100,-100)
> (with positive parameter extension works)
> I have serached in the geometry category but I didn't find anything
> similar to "reduce".
> Other question, related to the same geometry. I want to have the label
> curved and at the center of the arc and not of the line.
> I tried with the expression:
> translate( centroid( $geometry), $length/10, $length/10)
> in the "label anchor", but nothing happen :(
>   Any suggestion? Thank you!
> Cheers
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210617/283a39c2/attachment.html>
