[Qgis-user] Sum of field value within same cluster
Drew French
fullboarfarm at gmail.com
Tue Jun 22 07:35:38 PDT 2021
What if you create a class field based on areas defined by polygons and
then summed those classes? Then you can also use that field in your print
layout as well, which you cannot do using expressions.
On Tue, Jun 22, 2021 at 9:15 AM Charles Dixon-Paver <charles at kartoza.com>
wrote:
> I agree that I think there was a misunderstanding in the requirement,
> however I am unsure how you resolve this with expressions.
> In my view, an aggregate expression is what you need, but I am unsure how
> you would be able to retrieve the cluster geometry. The current expression
> is buffering each feature geometry so it's finding nearby neighbouring
> points, not identifying clusters.
> You could feasibly collect the geometries within each cluster and retrieve
> a centroid that is buffered using expressions, but identifying which points
> form a part of each cluster would be difficult.
> You could probably perform various K-means/ DBSCAN clustering operations
> to get this at the various scales that you need though, then use that
> attribute value with an expression similar to centroid(collect( $geometry,
> "CLUSTER_ID" )). Once that is done though, you won't need to use the
> spatial intersection in the aggregate expression anymore anyway.
> Again, you'll be challenged to find the right buffer distance to make this
> effective, and be able to exclude individual points. This makes the effort
> and utility of the automatic clustering symbology less than ideal for your
> use case as you could generate these styles yourself. It may be easier to
> pay a developer to expose the cluster geometry to the QGIS expressions API.
> Hopefully that's helpful and not totally confusing.
> Regards
> On Tue, 22 Jun 2021 at 15:03, Dario C <dario955i at gmail.com> wrote:
>> Hi Alexandre,
>> thank you for your reply, but I'm not sure I got it. I don't want to see
>> the @cluster_size (number of symbols within the cluster), but the sum of a
>> specific field.
>> I don't know what "@cluster_value" is. I see only @cluster_size
>> and @cluster_colour as options.
>> Thanks
>> Il giorno mar 22 giu 2021 alle ore 12:12 Alexandre Neto <
>> senhor.neto at gmail.com> ha scritto:
>>> Hi Dario,
>>> You don't need such complicated expression. There's a cluster variable
>>> that returns the value for you. It's @cluster_value.
>>> This is well documented here:
>>> https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/vector_properties.html#point-cluster-renderer
>>> Hope it helped.
>>> Alexandre Neto
>>> QGIS Support
>>> www.qcooperative.net
>>> A terça, 22/06/2021, 09:55, Dario C <dario955i at gmail.com> escreveu:
>>>> Hi,
>>>> I think I'm on the right way using this expression:
>>>> aggregate('LayerID','sum',"FIELD",filter:=intersects(buffer($geometry,60),geometry(@parent)))
>>>> [image: image.png]
>>>> In point cluster I set 5 mm as distance (size of symbol is 4mm), so I
>>>> thought that the buffer of my expression needed to be 5. Actually 5 does
>>>> not work, so I changed to 5 multiply by the scale of the drawing
>>>> (1/12.000), so I set 60.
>>>> The point is that it works not so precise. In the screenshot you can
>>>> see that, when you have two cluster close each other, the total sum is
>>>> correct, but some parts are shifted to another cluster.
>>>> Thanks for your help
>>>> Il giorno dom 20 giu 2021 alle ore 15:15 Dario <dario955i at gmail.com>
>>>> ha scritto:
>>>>> Hi,
>>>>> I’m working on a big scale, so I need to see my points using point
>>>>> cluster.
>>>>> I’d like to see as label the sum of a specific field of the point of
>>>>> the same cluster.
>>>>> I started using aggregate expression and buffer intersection as
>>>>> filter, but nothing good...
>>>>> Thank you in advance.
>>>>> Cheers mm
>>>>> _
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Drew French
(715) 986-8088
www.ecologicaldesign.land
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210622/c30aed7d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210622/c30aed7d/attachment-0001.png>
