[Qgis-user] QGIS - Vector layer with multiple entities
Edouard Bourgine edouard.bourgine at acosol.fr
Thu Jun 24 07:42:56 PDT 2021
I’m running qgis 3.16 on w10.
I have two vector layers with multiple entities :
·         One with each town borders (? I’m note sure if this is the right
word) I mean the area for each zip code. (TOWN_LAYER) (polygon vector)
·         The second with cropfields and meadows (polygon vector)
(FIELD_LAYER)
I want the total area of cropfield and Meadows in each Town from the first
layer. (Exemple : one town have 31 fields/meadows -> total town area is
55km² (i have that info) and cropfield/meadows area is 26km² (i need that
one for each town)
First i tried something like :
Sum(area(intersection($geometry,geometry(‘FIELD_LAYER_ID’))),group_by
:=FIELD WITH SAME VALUE EVERYWHERE)
But it is not a valid expression (geometry(‘FIELD_LAYER_ID’) don’t work)
Some meadows span over several town. Some juste inside one.
I’ve « cut » the FIELD_LAYER with the TOWN_LAYER
My first vector layer as a field specific and i’m looking for the formula
that would give me the right answer.
I’ve tried :
·         aggregate (layer :=’FIELD_LAYER_ID’, aggregate :=’sum’,expression
:=$area, filter := intersects($geometry, geometry(@parent)))
It doesn’t work because the borders are overlapping : each fields just
touching the borders even if they belong to another town are included.
« Contains » instead of « intersects » doesn’t work either because some
borders of the field are overlapping and those are not included.
Exemple with « count » instead of « sum »
A town have 31 fields spanning over 26km² : Intersects give me a total count
of 38 and 48km² and contains give me 12 and 4,7 km² because of borders
overlap.
I think the solution is with intersection, but i can’t reach a valid
expression.
Another solution may be splitting the FIELD_LAYER in as much layer as town
(I did that) and batch process for each layer :
·         sum($area,group_by := FIELD WITH SAME VALUE EVERYWHERE)
then get the result in the TOWN_LAYER.
But i don’t know how to batch process it and get the result in the first
layer.
And for informations I’m talking hundreds of towns and thousands of
fields/meadows entities so one by one calculation is not possible.
I hope I make sense and that someone know how to deal with that.
Thanks,
Edouard BOURGINE
Ingénieur Environnement
Tél/Fax : 03.83.22.69.09
Port : 06.63.12.99.63
ACOSOL
26 rue de l’Ornain
54520 LAXOU
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel antivirus Avast.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210624/5685e746/attachment.html>
