[Qgis-user] Refactoring line offset script - help
    Richard Duivenvoorde
    rdmailings at duif.net
    Thu Jun 24 11:30:11 PDT 2021
On 6/24/21 3:22 PM, Ryan Peel wrote:
> I cannot for the life of me refactor this code to get it to work for the latest version of QGIS.  Has anyone successfully been able to do this or could help?  The article is a few years old and I don't know if the author is still there to help.
> https://gis.stackexchange.com/questions/239129/shifting-display-of-overlapping-lines-in-qgis/239370#239370 <https://gis.stackexchange.com/questions/239129/shifting-display-of-overlapping-lines-in-qgis/239370#239370>
Hi Ryan,
I fixed both versions see below.
I left the old code in comments for reference, it's just a couple of lines.
Attached a screenie for the version which explodes all vertices and the one only using the first and last vertex.
Not guaranteeing it will always work (for one I think you will need single lines, not multilines), but as shown it works with me here...
Will try to put in on stackexchange too
Hope this helps:
Regards,
# ALL vertices
from qgis.core import *
from qgis.gui import *
from math import sin, cos, radians
@qgsfunction(args='auto', group='Custom')
def draw_wires(angle, percentage, curr_feat, layer_name, feature, parent):
    def wires(polyline, new_angle, percentage, referenced_columns=[]):
        for x in range(0, len(polyline)-1):
            vertices = []
            first_point = polyline[x]
            second_point = polyline[x +1]
            #seg = QgsGeometry.fromPolyline([first_point, second_point])
            seg = QgsGeometry.fromPolylineXY([first_point, second_point])
            len_feat = seg.length()
            frac_len = percentage * len_feat
            limb = frac_len/cos(radians(new_angle))
            tmp_azim = first_point.azimuth(second_point)
            angle_1 = radians(90 - (tmp_azim+new_angle))
            dist_x, dist_y = (limb * cos(angle_1), limb * sin(angle_1))
            #point_1 = QgsPoint(first_point[0] + dist_x, first_point[1] + dist_y)
            point_1 = QgsPointXY(first_point[0] + dist_x, first_point[1] + dist_y)
            angle_2 = radians(90 - (tmp_azim-new_angle))
            dist_x, dist_y = (limb * cos(angle_2), limb * sin(angle_2))
            #point_2 = QgsPoint(second_point[0] - dist_x, second_point[1] - dist_y)
            point_2 = QgsPointXY(second_point[0] - dist_x, second_point[1] - dist_y)
            tmp_azim = second_point.azimuth(first_point)
            angle_3 = radians(90 - (tmp_azim+new_angle))
            dist_x, dist_y = (limb * cos(angle_3), limb * sin(angle_3))
            #point_3 = QgsPoint(second_point[0] + dist_x, second_point[1] + dist_y)
            point_3 = QgsPointXY(second_point[0] + dist_x, second_point[1] + dist_y)
            angle_4 = radians(90 - (tmp_azim-new_angle))
            dist_x, dist_y = (limb * cos(angle_4), limb * sin(angle_4))
            #point_4 = QgsPoint(first_point[0] - dist_x, first_point[1] - dist_y)
            point_4 = QgsPointXY(first_point[0] - dist_x, first_point[1] - dist_y)
            vertices.extend([first_point, point_1, point_2, second_point, point_3, point_4, first_point])
            #tempGeom = QgsGeometry.fromPolyline(vertices)
            tempGeom = QgsGeometry.fromPolylineXY(vertices)
            num.append(tempGeom)
        return num
    #layer = QgsMapLayerRegistry.instance().mapLayersByName(layer_name)[0]
    layer = QgsProject().instance().mapLayersByName(layer_name)[0]
    all_feats = {}
    index = QgsSpatialIndex()
    for ft in layer.getFeatures():
        index.insertFeature(ft)
        all_feats[ft.id()] = ft
    first = True
    tmp_geom = curr_feat.geometry()
    polyline = tmp_geom.asPolyline()
    idsList = index.intersects(tmp_geom.boundingBox())
    occurrences = 0
    for id in idsList:
        test_feat = all_feats[id]
        test_geom = test_feat.geometry()
        if tmp_geom.equals(test_geom):
            occurrences += 1
    if occurrences & 0x1:
        num = [tmp_geom]
    else:
        num = []
    rapp = occurrences/2
    i=2
    new_angle = angle
    while i <= occurrences:
        draw=wires(polyline, new_angle, percentage)
        i += 2
        new_angle -= new_angle/rapp
    first = True
    for h in num:
        if first:
            geom = QgsGeometry(h)
            first = False
        else:
            geom = geom.combine(h)
    return geom
# only the start and end
def draw_wires2(angle, percentage, curr_feat, layer_name, feature, parent):
    def wires2(polyline, new_angle, percentage):
        vertices = []
        len_feat = polyline.length()
    layer = QgsProject.instance().mapLayersByName(layer_name)[0]
    all_feats = {}
    first = True
    #coords = tmp_geom.asMultiPolyline()
    #if coords:
    if tmp_geom.isMultipart():
        new_coords = [QgsPointXY(x, y) for x, y in z for z in coords]
    else:
        coords = tmp_geom.asPolyline()
        new_coords = [QgsPointXY(x, y) for x, y in coords]
    first_point = new_coords[0]
    second_point = new_coords[-1]
    #polyline=QgsGeometry.fromPolyline([first_point, second_point])
    polyline=QgsGeometry.fromPolylineXY([first_point, second_point])
    occurrences = 0
    for id in idsList:
            occurrences += 1
        num = [polyline]
    else:
        num = []
    i=2
    new_angle = angle
        draw=wires2(polyline, new_angle, percentage)
        i += 2
    first = True
    for h in num:
        if first:
            first = False
        else:
    return geom
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210624/6f6d5098/attachment-0001.jpeg>
