[Qgis-user] QGIS animation publish as web map
Charles Dixon-Paver charles at kartoza.com
Mon Jun 28 08:49:01 PDT 2021
Maps will not be able to animate themselves. You need to configure your web
map project to support temporal data from the QGIS server WMS-T (with time)
service. For starters, you could look at the leaflet plugins [1] available
for this, but the actual implementation depends a lot on what/ how you plan
on publishing your outputs. In the meantime you can export the animation
frames from the temporal controller and compile them into a video file for
static animation.
[1] https://leafletjs.com/plugins.html#time--elevation
On Mon, 28 Jun 2021 at 17:07, Alexander Zapp <alexZapp at gmx.de> wrote:
> Hello,
> Im using QGIS 3.18 and i create a timeanimatited map with GGIS time
> manager. I want to publish the animation with menu in a web map. I try it
> with qgis cloud but there is only the map with no animation. Is there a
> easy way or a way to publish the animation as a web map.
> Thank you for helping
> Cheers Alex
> Diese Nachricht wurde von meinem Android Mobiltelefon mit GMX Mail
> gesendet.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210628/cad12018/attachment.html>
