[Qgis-user] QGIS animation publish as web map
    Charles Dixon-Paver
    charles at kartoza.com
    Mon Jun 28 08:59:44 PDT 2021
Sure thing. After a few minutes of digging I found a demo which might point
you in the right direction:
http://apps.socib.es/Leaflet.TimeDimension/examples/example13.html
On Mon, 28 Jun 2021 at 17:58, Alexander Zapp <alexZapp at gmx.de> wrote:
> Thank you for your quick answer
> Diese Nachricht wurde von meinem Android Mobiltelefon mit GMX Mail
> gesendet.
> Am 28.06.21, 17:49 schrieb Charles Dixon-Paver <charles at kartoza.com>:
>> Maps will not be able to animate themselves. You need to configure your
>> web map project to support temporal data from the QGIS server WMS-T (with
>> time) service. For starters, you could look at the leaflet plugins [1]
>> available for this, but the actual implementation depends a lot on what/
>> how you plan on publishing your outputs. In the meantime you can export the
>> animation frames from the temporal controller and compile them into a video
>> file for static animation.
>> [1] https://leafletjs.com/plugins.html#time--elevation
>> On Mon, 28 Jun 2021 at 17:07, Alexander Zapp <alexZapp at gmx.de> wrote:
>>> Hello,
>>> Im using QGIS 3.18 and i create a timeanimatited map with GGIS time
>>> manager. I want to publish the animation with menu in a web map. I try it
>>> with qgis cloud but there is only the map with no animation. Is there a
>>> easy way or a way to publish the animation as a web map.
>>> Thank you for helping
>>> Cheers Alex
>>> gesendet.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210628/8a964866/attachment.html>
