[Qgis-user] Multiple lines issue in labelling
DelazJ
delazj at gmail.com
Tue Jun 29 01:18:59 PDT 2021
Le mar. 29 juin 2021 à 06:09, Patrick Dunford <enzedrailmaps at gmail.com> a
écrit :
> It comes down to a perspective of how intuitive a UI feature should be.
> The placement tab is a new feature in recent versions of Qgis and that's
> down to a subjective classification of things into "placement" options or
> whether there is a better way of classifying the settings that keeps them
> together in the same tab of the dialog.
You meant multiline is new feature (>= QGIS 3.4 I think) because placement
tab is an old tab (QGIS 2.0
<https://docs.qgis.org/2.0/en/docs/user_manual/working_with_vector/vector_properties.html#labels-menu>).
If you have suggestions, do not hesitate.
> You could put a message above the multiline section saying " this section
> is disabled because curved has been selected in other tab" or words to that
> effect.
Could help indeed. Mind opening an issue report or provide a pull request?
Thanks
Regards,
Harrissou
> On 27/06/21 6:51 pm, DelazJ wrote:
> Hi,
> These are quite different features I can't see how they would stay in the
> same tab, despite I understand your point.
> Anyway, note that the multilinear options are disabled because these
> functionalities are not YET implemented for curved labels. See
> https://github.com/qgis/QGIS-Enhancement-Proposals/issues/62
> Regards,
> Harrissou
> Le 25 juin 2021 04:43:11 GMT+02:00, Patrick Dunford
> <enzedrailmaps at gmail.com> <enzedrailmaps at gmail.com> a écrit :
>> Yes it was set with that.
>> This does raise a question of the software design. I got an introductory
>> course in interface design many years ago, and we were taught a control
>> that enables or disables a part of a user interface should not be placed in
>> a different page of a multi tabbed dialog.
>> On 25/06/21 1:08 am, DelazJ wrote:
>> Hi Patrick,
>> Do you set a curved placement for the labels?
>> Harrissou
>> Le jeu. 24 juin 2021 à 13:22, Patrick Dunford <enzedrailmaps at gmail.com>
>> a écrit :
>>> Good day
>>> I have used the multiple lines feature in labelling some of my layers.
>>> However for some inexplicable reason this section in some layers is
>>> grayed out (disabled) and cannot be accessed.
>>> All layers are Spatialite but this should have no relevance as the
>>> labelling settings are stored in the project file rather than with the
>>> layers data files.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Envoyé de mon appareil Android avec Courriel K-9 Mail. Veuillez excuser ma
> brièveté.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210629/a597a7b7/attachment.html>
