[Qgis-user] contours and symbology
Sebastian Gutwein
bas at rdgland.com
Wed Mar 3 11:21:38 PST 2021
Bernd,
Thanks for the hint.
The % operator description in QGIS only says: Remainder of division
This has thrown me off in the past because I have tried to search for the
Modulo in the expressions dialog and nothing came up.
I should probably request a change to add the modulo term at the QGIS git
hub.
On Wed, Mar 3, 2021 at 1:45 PM Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
wrote:
> In case someone wants to google for the " % " later: it's called modulo
> operator (damn, took me half an hour to remember that)
> On 03.03.21 19:20, Sebastian Gutwein wrote:
> Sorry typo: "ELEV" :The attribute field that contains your elevation
> On Wed, Mar 3, 2021 at 1:19 PM Sebastian Gutwein <bas at rdgland.com> <bas at rdgland.com> wrote:
> I use rule based styling with this expression for my 100m contour filter
> rule:
> "ELEV" % 100 = 0
> And then another rule that has the Else selected.
> The formula is:
> "ELEV" :The attribute field that contains your label
> % : The remainder from division
> 100 : the divider
> = 0 : the remainder should equal zero.
> This filters all the 100m contours.
> On Wed, Mar 3, 2021 at 1:01 PM Azzurra Lentini <azzurralentini at gmail.com> <azzurralentini at gmail.com>
> wrote:
> Hi to all,
> I have extracted contours from a dtm raster 20 m resolution file and the
> result is a vector file of contours with 20 m of interval between the
> contours.
> I would like to have two different symbols for these contours: for
> example black colour and thickness 1 for the contours with interval of 100
> m (0, 100, 200, 300 etc.) and grey colour and thickness 0.5 for the
> contours 20, 40, 60, 80, 120, 140 .. etc.).
> What can I do?
> Normally I create another contours file only for the contours equidistant
> 100 m and I put a different symbol for the 2 layers.
> Do you know other ways without the creation of another file?
> maybe rule-based symbology?
> Thank you, Azzurra
> Lecturer GIS University "Roma Tre"
> Consultant Environmental Risk Prevention and Hydrogeology
> AZZURRA LENTINI
> Italy Mobile Tel.: **(39) 338 24 40 676
> SKYPE azzurrahydro
> *azzurralentini at gmail.com <azzurralentini at gmail.com> <azzurralentini at gmail.com>*
> *azzurra.lentini at uniroma3.it <azzurra.lentini at uniroma3.it> <azzurra.lentini at uniroma3.it> *
> *Par respect pour l'environnement,*
> *n'imprimez ce mail qu'en cas d'absolue nécessité*
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210303/a68fa0ae/attachment.html>
