[Qgis-user] Lidar download
Martin Dobias wonder.sk at gmail.com
Fri Mar 5 05:35:24 PST 2021
Hi
On Fri, Mar 5, 2021 at 3:13 AM Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
>  LiDAR is new in QGIS and i’am not sure what files formats are supported
> yet.  I had trouble with the current version.  It did show support for a
> json file format but I expect the las/laz format support will pop up once
> the bugs are worked out.  In the mean while, I would use CloudCompare
> (OpenSource) to read the cloud and create the DEM.  Then, you could import
> the DEM into QGIS to extract the contour lines.
QGIS 3.18 does support LAS/LAZ format to load point cloud datasets. The
problem is that some installers for some platforms (most notably the
Windows installer) do not include the PDAL library needed to read LAS/LAZ
files. There is now an experimental alternative installer which includes
also PDAL library and thus it can read LAS/LAZ files too:
https://qgis.org/downloads/QGIS-OSGeo4W-3.18.0-1.msi
Please note that 3.18.0 release has been pulled back few days ago because
of several major bugs, so please consider this as a testing release where
some things may not work.
Regards
Martin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210305/ac063732/attachment.html>
