[Qgis-user] Trimble GeoXT 2005 Accuracy
kirk
kirk at nortekresources.com
Sat Mar 6 15:56:40 PST 2021
A few notes.sbas which is waas in north America is based on equatorial satellites which will get you in the 1 m range in southern Canada. you can achieve sub decimeter accuracy consistently using rtk ,either through a ntrip caster (base station) broadcasting over the intenet or with your own base station and a radio link. there are a few chip sets and break out boards that you acquire and assemble your own system. This is a very inexpensive option.Another option in Canada is to use precise point positioning (PPP) which requires 6 to 12 hours of observation data using L1, L2 or L1 and L2 data and rinex log files. This comes in handy if you need to establish a remote base station.A proper antennae with a metal ground plane is also critical to getting quality results.Observing under a forested canopy is difficult especially in summer under leaf on conditions, after a rain which creates multiparth mayhem.There is a reason survey grade equipment is relatively expensive. If you require repeatably accurate results in a variety of conditions this is an option.Kirk Schmidt Sent from my Galaxy
-------- Original message --------From: Jorge Gustavo Rocha <jgr at geomaster.pt> Date: 2021-03-06 6:41 p.m. (GMT-04:00) To: qgis-user at lists.osgeo.org Subject: Re: [Qgis-user] Trimble GeoXT 2005 Accuracy
I just jump in this thread to say I'm really impressed with
Ardusimple. I have a RTK Handheld Surveyor Kit [1] for +- 400 €
and it works really well.
I use the national NTRIP service and I have consistently
precisions around 10 cm with just one receiver.
I use a free Android application called SW Maps [2]. My survey
points, tracks and photos are collect in a geopackage that I can
read in QGIS. I use it mostly to collect ground control points for
my drone flights.
Regards,
Jorge Gustavo
[1] https://www.ardusimple.com/product/rtk-handheld-surveyor-kit/
[2]
https://play.google.com/store/apps/details?id=np.com.softwel.swmaps
Às 20:12 de 06/03/21, Greg Troxel
escreveu:
Springfield Harrison <stellargps at gmail.com> writes:
Thanks Dan. See my relies to Kirk and Greg. The Emlid sounds
interesting, will have a look.
I have an earlier Emlid Reach (not RS or RS2), which has L1 only, and I
never got it to work well.
Also look at the Ardusimple unit -- but it's more a parts kit than a
system. You need a way to get RTK reference data in, and a good
antenna. One approach is Vespucci (OSM editor for Android) as a
datalogger, and the Ardusimple WiFi NTRIP master to get corrections over
the phone's hotspot.
https://www.ardusimple.com/product/simplertk2b/
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Email Signature
Geomaster
Jorge Gustavo
Rocha
| Software Engineer
e: jgr at geomaster.pt
| m: +351 910 333 888
g: 41.54094,-8.40490
| v:
510 906 109
a:
Rua
António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210306/1cfb69df/attachment-0001.html>
